Question about Samsung RS2630WW Side by Side Refrigerator
Rs2630ww How can I tell if the fan on the back is not functioning. The center column is very hot. Secondly, if the fan is not working, is that part of the warranty? My fridge is ~14 months. thanks. dlee
  • 1 more comment
  • sdesai Nov 09, 2007
    Tempratures inside the freeze is warming up does not seem that it is working anymore, but the light is ON.
  • bmajor Apr 14, 2008
    freezer is getting warmer and the back of the fridge is hot fan not spinning ice maker stopped producing ice 2 days ago and the wall that divides freezer from fridge is burning hot
  • gfong Apr 28, 2009
    HVACRH20 was absolutely correct. The compressor was overheated on my rs 2630 and the compressor fan was the cause. Very easy fix.
  • 237 Answers
You should be able to see the fan spinning if you look under the frige with a flashlight to the back or feel air flow (tissue paper helps) coming from underneath it. As for the center column, if you mean the divider area between sides, that being real hot means the compressor refrigerant is overheated. It should be warm to touch not hot. Sounds like your condensor fan is out or packed full of dust bunnies and not spinning. The compressor will overheat and "trip" the thermal overload on and off so you do need that cooling fan. All the underside of the frige needs to be clean and clear of hair, pet fuzz, etc. in order to cool properly. The fan is likely out of warranty but they are cheap and easy to replace by a homeowner.
Posted on Dec 20, 2006
SOURCE:
The fan made some bad noise and now the front center part of the refrigerator is almost too hot to touch. I took the back slide of the refrigerator off and it seems the fan isn't working. I tried turning...
Yes. Usually the motor does not come with the fan blade. You should unplug it until you replace the fan motor or set up a portable fan to blow on the compressor and coils.
Sep 21, 2010 | Samsung RS2630WW Side by Side Refrigerator
We have recently noticed that the part of the refrigerator that separates the freezer from the refrigerator is very hot to the touch on the Samsung RS2630WW Side by Side Refrigerator. It also seems hot on...
This is a sure sign of pending compressor failure (high heat and head pressure, Since that 2 inch section comes directly from the compressor.For verification,
Remove the back cover, and place your hand on the compressor.(careful,may be hot) should be able to leave your hand on compressor without burning.
Check condensor fan in that same area , It may be not running
causing all the trouble
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Sep 09, 2010 | Samsung RS2630WW Side by Side Refrigerator
I have a Samsung RS2630WW Side by Side refrigerator. The center column dividing the freezer from the refrigerator is very hot to the touch. The freezer and refrigerator are working fine. Is this a...
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Aug 13, 2010 | Samsung RS2630WW Side by Side Refrigerator
The middle bar on my side by side refrigirator is very hot!
hi,i want to tell you i don't work on samsung fridges,they just don't give techs any info,you have to work with samsung to get any info but on any other fridge if the strip is hot or really warm either the condenser coil on the bottom is clogged with dust or the condenser fan isn't running to cool off the compressor and blow the hot air across the condenser coil,so remove the bottom front kick panel and see if the coil is clogged,they have had alot of problems with the computer board to so if the board is bad the fan might not be blowing fast enough to cool it down but check it to see if the fan is blowing,pull the fridge out,remove the bottom panel and check the fan,i've seen other machines do this,and the fan has to be ordered,if you get a house fan and blow it on the back where the compressor is it should help cool it down so you don't cook your compressor and you won't loose any food until you get it fixed.i hope this helps you out and good luck,call whoever you bought it from or call samsung and they will send a certified tech there to help you out or go here to look up parts,if it is the fan motor you can replace it if you want to give it a shot.go here put your model number in and look up parts
https://www.searspartsdirect.com/model/search.html?q=lt608
Feb 04, 2018 | Samsung RS2630WW Side by Side Refrigerator
The center divider (between the doors) gets so hot you can't touch it. Other than that- it works and cools just fine.
ok that is entirely normal
that is your moulion heater, it is ment for two things
a. it keeps your seals soft and plyable
and b. it controls hot air entry to the unit when you open the door
it offsets the heat barrier with the door open,
that is what stops humidity from building up oin the machine
Oct 16, 2009 | Samsung RS2630WW Side by Side Refrigerator
The center of the fridge between the freezer and fridge is so hot you cant touch it whats wrong should I call a repair person ? thank you for any help
HI, this is a sign the fridge isn't cooling proper. Check and see if there is frost building up on the rear panel of the freezer. Check and see if the evaporator or the condensor fan motors are running. Check and see if the compressor is running.
Pleasae let me know if I can assist you fyrther.
Vic
May 21, 2009 | Samsung RS2630WW Side by Side Refrigerator
CENTER METAL SURFACE THAT DOOR SEALS TOUCH WILL BURN YOUR SKIN
go to partstore buy the part # DA97-01949A and fix it you can put the fan in back refrigerator keep it cool when the part come and fix it
May 11, 2009 | Samsung RS2630SH Side by Side Refrigerator
Fridge and Freezer do not keep foods cool
Samsung rs2630ww i have had endless problems i have had it replaced 4 times. red hot center and side panels i have had 2 condensers burn. the problem is that it is simply badly designed!
there is not enough air flow . so if it has any restriction it kills the unit. a Samsung tech told me off the record these units are all problematic! of course he love it at 200 an hour.
Aug 01, 2007 | Samsung RS2630WW Side by Side Refrigerator
Rs2630ww
Dec 19, 2006 | Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator Logo
392 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
