Question about Panasonic Audio Players & Recorders
I keep getting error code H02 after cd is in machine
Machine says there is "no disc" after I put one in the machine and it can't read it. Error code H02 shows up on machine. What is it all about?
Remove the cover from the player, usually a few screws on the sides and back. You will see the changer and the drive at the back (Panasonic SC-PT750). Start the play sequence and while it is attempting to read, gently start the the disk spinning near the center in a clockwise direction with your fingertip. The motor should kick in at this point. Others out there (and me) have left the cover screws out, as it will not be the last time you have to do this most likely!
Posted on Jan 27, 2009
Why the Panasonic Washing Machines error code "h 02" displaying?
Google "panasonic washing machine error codes"
Jun 11, 2016 | Washing Machines
On my Husqvarna Viking sewing & embroidery machine...when I put in a floppy disc I get the error message: General disc error. What is wrong?
It can't read your disc, it may be damaged or needs to be cleaned. It could also be the wrong disc for the machine. The machine can't recognize it.
Jan 24, 2014 | Husqvarna Sewing Machines
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
ERROR CODE H02 ON MY HOOVER SENSOR DRY WASHER DRYER WD9616C
Hi I have the error code ho2 on my Hoover wash machine does any one no what it means
Oct 21, 2012 | Washing Machines
Error H02 for panasonic dvd s35
My Panasonic DVD Player Model S55 does not read the DVD disk. I get a H02 then no disk reading on the display.
Jan 17, 2010 | Panasonic DVD-S35 DVD Player
ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Dec 01, 2009 | Panasonic Televison & Video
I keep getting the error 3 message when putting a cd into my durabrand am/fm cd player what can i do to fix this?
Error 3 is typically a code for not reading the discs at all. Try a lazer cleaner I have the same problem in my car with a stock cd player.
Sep 12, 2009 | Car Audio & Video
PANASONIC SA-HT800V
Ouch - This generally one of two things.
1 - Run up speed is not sufficient due to motor wear.
2 - The laser head sits within a 'plastic' runner, which wear down slowly, causing the laser to be misaligned - therefore not reading adequately.
Depending how adventurous you are feeling - you could dismantle the unit - and 'space off' the laser unit (Single piece of paper) this will lift up the laser.
Or you may be able to adjust the calibration power of the laser using a variable pot (unlikely to be available as these are generally hard coded nowadays - and not physical pots)
Aug 15, 2008 | Panasonic DVD-LA95 Portable DVD Player
Error H02
I had the same problem and found that the motor that spins the cd so it can be read would start and stop. I opened the case removed the assembly with the motor and placed a drop of 3in1 lightweight oil on the shaft of the motor ran it a few times and now it works perfectly fine. Good luck hope this helps you as well.
Dec 21, 2007 | Yamaha DV-C6480 Multi-disc DVD Player
397 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
