How to do phone creid cards - Office Equipment & Supplies
    Genius:
  • 2,120 Answers
Plug the phone line from the Credit Card Machine into the port marked with TEL or a telephone icon.
Posted on Nov 21, 2008
Why do they need a creid card number when downloading utube on the 3DS
i've never heard of youtube asking for credit card info, unless it is some youtube(plus) service. if it's just the regular youtube, none is needed.
Jan 01, 2015 | Nintendo 3ds Handheld Game Console- Cosmo...
Memorey card is not work in a phone
Hello, welcome to Fixya!
The fault is either from the phone or the phone's memory card slot.
Test the memory card on another phone or any other device that uses memory card. If the memor card doesn't work, then it means the memory card is not good. But if the memory card works, it means fault is from the phone.
Get a phone screw driver, disassemble the phone, clean the memory car slot with a tooth brush. This will clear off all particles that maybe preventing the memory card from contacting the phone properly.
The cleaning the memory card slot doesn't help, it means the memory card slot of the phone is defective. It takes only a repairman to fix this fault for you.
I hope the above information is celar.
Regards.
Walesarumi
Dec 14, 2011 | Samsung Lands Phones
Phone says no card when 8gb card is in
have you inserted the card? if yes, open the settings for your phone, look for your memory card and have it formatted through your phone. your card needs to adapt the phone properties first before you can use it.
if that step didn't work, it's better to check your memory card while using friend's phone. consult your phone specifications also for some clarifications, try to check if it can support 8 gb memory cards.
regards.
Feb 28, 2010 | Sony Ericsson Satio Cell Phone
MicroSD card problems
Try letting the phone format the card. 1) Backup the music files you already have on the card. 2) From your computer, right click on the drive representing the card and re-format the card. 3) With the phone turned off, insert the card into your phone. Power on the phone and follow the steps to have your phone format the card. 4) Now copy the files back to the card using your computer.
See if that does the trick. If not, try performing the same steps as above, but instead of re-formatting the card in your computer, go into disk manager and delete the MicroSD card's partition (be careful that you select the correct drive representing your MicroSD card). When you re-partition the card, uncheck the "format" option, which will leave the card unformatted. Then let your phone format the card.
Good Luck!
Aug 13, 2009 | Samsung SGH-P850 Cellular Phone
Emissions test comes up not ready - can't pass inspection
Under the hood, there is a fuse block. I believe it is on the driver's side of your vehicle. Open that box, and pull the "ECU" fuse. Leave the fuse out for at least 5 minutes. Put the fuse back in, start the car, and let it idle for at least another 5 minutes. Do not drive the car, touch the gas, or even look at the gas pedal for these 5 minutes, as the ECU is remapping itself. This will properly reset the ecu and clear the codes. After this you may drive the car.
May 28, 2009 | Hyundai Motor 2004 Sonata
My cell phone dont recognize memory card that i was using
Hi there, I assume that you are changing the card from the original phone to another model or brand of phone - if so, then it is likely that the card is formatted to the original phone and as such will not be read by other phones (hence your error message).
There will be a function in the phones that will format the card to that phone, but be aware that you wil lose all information on that card.
Feb 06, 2009 | Adaptec Electronics - Others
Phone memory card
hi first u should format ur memory card from computer with help of card reader but u should format the card fully not choose the selection of (quick format).then put into mobile.if problem not remove then ur card is corrupt u must buy a new card.
take care byee
Dec 02, 2008 | Cell Phones
Wildcard sim card problem
There is no sim card in the phone. Only certain phones and phone networks use sim cards. a GSM network, like AT&T uses sim cards.
Nov 02, 2008 | Kyocera wild card Cellular Phone
Memory problems Nokia N95
Bit of a long shot, but take the card out and clean the gold contacts with a pencil eraser (a hard eraser is best).
Make sure there are no bits of rubber on the contacts when you put the card back in :-)
Switch the phone off and push the cleaned card in and out a few times. Good luck.
Oct 29, 2007 | Nokia N95 Cellular Phone
22 people viewed this question
k24674
jasbo
jasbo
