Question about Brother Office Equipment & Supplies
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
    Genius:
  • 2,120 Answers
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Posted on Nov 21, 2008
The keys typed are not the letters coming up
The SX 4000 is a "Daisy Wheel" printer. A plastic Wheel with the letters embossed on them spin via the input of the keyboard. I would suggest that your Daisy Wheel mhas slipped its index, presenting a offset letter., or the wheel is on inproper, but I do not see how it could happen, short of forcing it on. You may have to buy another Daisy Wheel, if that one is broken at the hub. See:
http://www.google.com/products/catalog?rlz=1T4SUNA_enUS250US259&q=daisy+wheels+for+brother+typewriters&um=1&ie=UTF-8&cid=5918209752341457784&ei=aqEHTeebDs6s8AaP-9nnAg&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDEQ8wIwAw#
Dec 14, 2010 | Brother SX-4000 Typewriter
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
My typewriter (Brother GX-6750) does not print correct letters
look for bent or broken spokes on daisy wheel .turning unit off for 20 seconds and back on should reset the daisy wheel home position. probably the daisy wheel.
Oct 26, 2009 | Brother ML-100 Typewriter
BROTHER ELECTRONIC AX-22 RANDOM LETTERS
Check to see if there is a switch on the left side of keyboard for international or symbol printwheel selection.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 17, 2009 | Office Equipment & Supplies
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
HELP PLEASE!!!!
I just talked to A Brother Customer Service Agent, I have a EM-530, and was having the same problem with my keys and symbols. Turn off your typewriter, hold down your Code, Shift and Tab key at the same time. Keep holding them down while you turn your machine back on. This will restore your factory settings competely. You will have to change your margins and tabs to where you like them again. If it continues to not type the write symbols, push code and the letter "K" and watch the upper left lights with roman numerals I II & III (KB is under the numerals), when the light is just on roman number I, let up the code key, turn off for ten seconds and then turn it back on. The keyboard has now reset and all should be well.
Mar 11, 2008 | Brother EM-530 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
How to get the @ sign
You should just have to hold the shift key down and type the @
Aug 10, 2007 | Brother ML-100 Typewriter
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
