Question about Dirt Devil Easy Steamer Upright Wet/Dry Vacuum
Ease Steamer MCE 7100 blown Diode, thermal protection device?????
I have the Easy Steamer CE 7100 that you can hear the what appears to be vacuum suction but the brush does not turn. I found a burnt what i would guess to be a diode. When i took the shrink tube off the wires fell off of it. Can you tell if if this is a diode or some sort of protection device. What is the P/N or rating and which color wires go to which side...Thanks..Paul
    Top Expert:
  • Dirt Devil Master
  • 12,962 Answers
Check out with mfg customer service dept.
Posted on Sep 05, 2017
SOURCE: I have a dirt devil
I have always bought dirt devils and this last on that I got is bad it dose not clean by the base boards like the others it dose not pickup stuff from the floor like the others, when you add one of the attachments to it that takes away from the sucking power and that power brush is a joke. I used it twice and it broke. I am not happy with this one at all.I have thought real hard about changing to a differant brand.I don't know what happened but something has to change.
thank you for your time atti
Posted on Jul 12, 2008
SOURCE: M1300 i dirt devil brushes wont roll
Ok I would say the belt burnt into if you can turn it on and the motor runs it is the belt . I would pull it apart and replace the belt.
Posted on Feb 25, 2009
  • 10 Answers
SOURCE: Dirt Devil Swivel Glide Platinum vacuum suction problem
Is the suction tubing in the head assembly clogged, is the belt broke? If the if the belt looks good the brush may be turned off and you may need to turn the brush switch on.
Posted on May 26, 2009
SOURCE: I lost the manual for my Dirt Devil Easy Steamer
You can get it here.
http://www.dirtdevil.com/search.aspx?q=MCE7000&type=3
Right click and download the file.
Then open it with Adobe Reader or FoxIt Reader. I just got one!
Posted on Dec 07, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: brush belt is broken,does this affect the suction
Yes, with this vacuum the belt being broken will cause a loss of suction.
Posted on May 18, 2010
Testimonial: "I suspected this,Ijust didnt want to buy the beltand be wrong..thank you soo much for an honest answer."
What? I have a Dirt. Devil easy steam carpet shampooed model CE 6300 HD. It was working great and then just stopped spraying out cleanser/water! Is there a manual or does anyone know how fix this problem?
Hello! You may need to prime the trigger to get the solution to start flowing. To do this, recline the handle and pump the trigger about 30 times. Then, turn the cleaner on and hold the trigger in for 30 seconds. The solution should begin to dispense. Be sure you are only using the cleaning products specified for use with this unit. Hope this helps! If you still need assistance feel free to reach out to use here on Fixya, Facebook.com/dirtdevil or Twitter @DirtDevil.
May 09, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt devil easy steamer does not steam
have you put water in it, and that it does not leak out does it get hot
Oct 04, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
Steamer has quit steaming. I have not used distilled water (didn't know I was suppose to. It seams to be stopped up.
Any device that actually makes steam should use distilled water. You are boiling away the water to make steam. Everything in the water that is not water will remain in your 'boiler'. So, what to do now ... treat it with vinegar. Vinegar should disolve the minerals left in your boiler.
Thanks for your question @ FixYa.com
Sep 13, 2011 | Dirt Devil Easy Steamer Upright Wet/Dry...
I was given a model 6591, plugged it in and it worked but didnt "****" and didnt sound right. I turned it off and removed the hose from the back found a badly plugged hose. Removed the hair...
The User Guide for the bissell Clearview Power Trak
http://canada.bissell.com/images/UserGuides/3590C.pdf
May not be your exact model but should be similar.
The Bissel vacuums include an internal thermal protector to protect it from overheating. When the thermal protector activates, the cleaner will stop running. Should this happen proceed as follows:
1. Turn the cleaner OFF and unplug from electrical outlet.
2. Check the Pre-Motor Filter and Post-Motor Filter for dirt accumulation.
3. Remove any clogs.
4. When the vacuum is unplugged and motor cools for approximately 30 minutes, the thermal protector should automatically resets and cleaning may continue.
5. If the thermal protector continues to activate after following the above steps, your cleaner may need servicing. Call Bissell Customer Service:
http://canada.bissell.com/Contact_Us.aspx
Mar 20, 2011 | Bissell 6591 Power Trak Revolution Bagless...
Shark Steamer model S3325 will not power on; switch appears to be working but will not indicate on and will not heat tank. I can hear it try to start the heating element (secondary clicks) however, does...
There's a thermal fuse inside. If it gets too hot, the fuse will blow and the thing won't turn on.
It has a 216 C temp limit. You can find thermal fuses at radio shack for less than 5$. If you're adventurous enough, you can find the fuse in line of a white wire under a fiberglass outer and heat shrink inner shielding screwed against the bottom of the tank.
Dec 28, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
I lost the manual for my Dirt Devil Easy Steamer CE 7000. Do you have a manual that I can download?
Jul 03, 2009 | Dirt Devil Easy Steamer Upright Wet/Dry...
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hi have a nice day!
CE 7100 may be similar to yours.
Have a look at item 32 HERE
Sep 25, 2007 | Dirt Devil CE6000 Featherlite Wet/Dry...
Dirt Devil Easy Steamer Upright Wet/Dry Vacuum Logo
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
