Question about GoVideo DP7240 Portable DVD Player with Screen
Help with Portable DVD
I have a Go Video DP7240 and initially it worked fine. I connected it to a 13" tv that I have with the rca cables in the front of the tv to view some dvds on a larger screen. The picture initially showed on both the tv and dvd player, but then went out on the dvd player, but continued to show on the tv. when I tried to go back to use the portable in the car, the picture would show for 10 sec (I would get thru the loading screen, then it would show dvd) then it would go black. when I push the lcd button on the remote, it flashes the pic for about 5 secnds then goes black again. Also, I can now only hear thru the head phones. I can no longer hear thru the speakers on the player. HELP!!!
  • jeanbean Nov 10, 2007
    I have a Zenith portable dvd player and the same thing happened.
    We plugged it into the tv and now the dvd players LCD screen is black,,,Won't light up...We have only had it for 3 hours,,,Help!
  • 4102 Answers
SOURCE: Go Video DVD player remote has gone haywire!
it sounds like your remote has got damp or over time the dust builds up behind the buttons you should be able to take the controll apert and remove the buttons check the pads are clean and not greasy then wipe over the board with some clean cotton cloth where the buttons pads press on to activate usually its just a bit of grease but check their is no button jammed it sounds like this could be the case as you get a different response to pressing the play button so try this first then if dont work still clean the buttons and pads be carefull not to dammage the pads they should come out all together and have little black pads stuck to them make sure their xlean and grease free if this still dont work then you can get but make sure its not one of the cheaper ones a all in one remote this should solve your problem hope this helps
Posted on Oct 30, 2007
SOURCE: Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Posted on Dec 24, 2007
  • 55 Answers
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
Posted on Jan 16, 2009
  • 303 Answers
SOURCE: Lost power cords
click on hyperlink
buy replacement ac power adapter for GO VIDEO GOVIDEO DP7240
Posted on Feb 12, 2009
Jannarama
  • 14 Answers
SOURCE: TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Posted on Mar 19, 2009
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
Dec 20, 2010 | Durabrand DWT1304 13" TV
Can't get signal from drc6309 to video/audio input
I dont have a Solution but I have the same problem with my RCA portable dvd DRC6309. I have connected it to three different tv set and I get no Video but I do get Sound through the tv sets... I have sent an e-mail to RCA costemer support hoping for a solution. If I hear anything back I will post it here...
I bought my RCA DRC6309 about a month or two ago at a Wal-mart supercenter. They no longer sell RCA portable dvd players. That is why I contacted RCA directly.
Jul 31, 2009 | RCA DRC6331 Portable DVD Player
Does my toshiba model have a digital tuner?
Negative. Here are the specs for your TV/DVD combo: I hope this solution is helpful. Please take a moment to rate this solution.
Toshiba MD13M1 Dvd Type: DVD player - built-in
Media Type: DVD, CD, Video CD
DVD Repeat Modes: A-B repeat, title, chapter
CD Playback Modes: Program play, random play / shuffle, all tracks repeat, one track repeat
Tv tuner Analog TV Tuner: NTSC
Reception System: NTSC-M
Analog Channel Qty: 181 channel(s)
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
MTS Stereo: Yes
Secondary Audio Program (SAP): Yes
Video features Closed Caption Capability: Yes
Closed Captioning on Mute: Yes
Remote control Type: Remote control - infrared
Features: Back-lit buttons
Connections Connector Type:
  • 1 x headphones ( mini-phone stereo 3.5 mm ) - front
  • 1 x composite video/audio input ( RCA phono x 3 ) - front
  • 1 x SPDIF output ( RCA phono ) - rear
  • Composite video/audio input ( RCA phono x 3 ) - rear
  • 1 x antenna ( F connector ) - rear
Jan 28, 2009 | Toshiba MD13M1 13 in. TV/DVD Combo
Zenith SMS1943S made 1995 Need code to switch to dvd status
nleebrooks,
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
cheers,
mark
Jan 17, 2009 | Zenith C13A05LG 13" TV
DTV hookup for an RCA XL-100 TV
Buy a box modulator which have RF input then have RCA output that's input to your TV or other option below.
Just click and choose whatever hooked up connection you want;
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ..
Plasma or Video Projector Wiring Guide
Blue-ray Surround Wiring
HP TVs - TV Cable and Connection Types
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jan 07, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
GPX portable dvd player does not play on bigger tv with rca cable
You have to buy the $15 video cable from GPX. I tried several differant cables including RCA to S Video as a last resort. They say theirs is propritary and I now believe it!!!
Jan 01, 2009 | GPX PD708B Portable DVD Player
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
RCA works fine when watching dvd but when cable is hooked up...
Similiar problem on this Chassis,( Popping + Sreeen Collapse)
Found Leaky 470 uf cap. near vertical output ic .( B+ Filter)
TechServices @Gmail.com
Sep 05, 2006 | RCA F20TF10 20" TV
GoVideo DP7240 Portable DVD Player with Screen Logo
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
