Question about Intermatic Inc. ST01C Digital In-Wall Timer
Can't operate manually
"battery" flashing need to over ride and locate new battery
  • Scott Jelt
    Scott Jelt May 11, 2010
    What model switch is it?
Open following link to identify timer and download manual with information on battery
Posted on Oct 04, 2011
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Dec 01, 2015 | Heating & Cooling
How do i change the battery in L170 bobcat?
these compact units are tough to work on , the battery is located under the seat , but you cant get it out thru the service port there , unfortunly you need to raise the operators cab up , youre gonna need a hoist or crane if done in field 4 that there are are two remote jump posts located just inside rear access door that allows one to jump it to start and drive to service bay or trailer , as with any computer/electricial work allways OBSERVE poliarty of connections , cat tends to use black wires for both sides of battery , and if you get it wrong you just bought a new ECM (expensive!!!)
Dec 15, 2014 | Garden
Where is the fuse box on gt 5000 craftsman lawn mower?
If you think your riding lawn mower has blown a fuse, trying to locate that fuse may be the most challenging step in replacing it. While different lawn mower manufacturers have located the fuse holder in different areas of the lawn mower, the best place to start looking is near the mower's battery, according to Sears.
Some manufacturers have made it easy to find the fuse holder. Simply lift the hood. The fuse holder is molded into the metal right inside the hood, near the battery. (See photo at Ref. 3, p. 53) If the battery is located beneath the seat, you may find the fuse holder located beneath the rear fender. Other manufacturers make it more challenging, placing the fuse inside an electrical box, located behind the mower's upper air baffle. (Ref. 4, p. 28) Fuses can also be located on or close to the edge of the mower's electrical panel, above the solenoid.
If you check these locations and still cannot find the fuse holder, check your operator's manual for a diagram of the electrical system, which should display the fuse's location. If you no longer have your manual, it may be available online through the manufacturer's website. Should you be unable to find a manual, call a local lawn mower dealership or lawn mower repair shop and ask for assistance in locating the fuse in your exact model.
Jun 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
We were given this vehicle and unable to find the where the batteryis located
You can download the owners manual here: MANUAL.
Most of the batteries are located behind the front bumper. There are tabs on the sides in wheel wells to release the front panel and it pivots downward to access the battery compartment.
Jan 20, 2011 | Peg Perego John Deere Gator HPX Ride on...
Put a new battery on it and still wont turn over
Check all of your safety circuits: Drive safety, blade safety, seat safety.
Naturally, ensure that your key circuit is operating.
Dec 20, 2010 | Troy Bilt 175HP Manual 42" Riding Mower
New battery charged, just won't go
What do you mean "Won't go?" Check the manual for the location of a lever lock which is manually set. Disengage it and you should be fine. If this isn't your problem
Oct 28, 2010 | Peg Perego John Deere Gator HPX Ride on...
Need to get an operator's manual for Troy Bilt Riding Mower Model No. 13AJ60967661A174H20136
Use the MTD company link above to locate the manual.
Nov 07, 2009 | Garden
Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Jun 16, 2009 | Garden
Have new battery for gator. where does it go?? also lost key
It doesnt use a key , that is just for looks. You will need to open the compartment that the front grille is attached to to locate the battery compartment.
Dec 20, 2008 | Peg Perego Peg-Perego Battery Operated Bed...
Operating new camera
1st thing to do is to read the manual. There is a comprehensive manual on the software dis that came with the camera in addition the the quick start booklet. Fow the camera to operate it needs batteries,and memory card installed. then switch on and pop away. But get to grips with the book it tells you all you need to know.
Dec 29, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Intermatic Inc. ST01C Digital In-Wall Timer Logo
113 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
