Question about Lenovo ThinkPad T61 Notebook
Dvd-rom not recognized by laptop
Can you send me the tool your talking about?
djrickgascon@netscape.net
really appreciate it.
Dvd rom in samsung laptop 300E failed to be recognized
boot live os cd
if its ok
problem in your os
Mar 11, 2014 | Samsung X05 Notebook
I'm running my laptop on win XP and I've got a problem with my CD/DVD-ROM somehow my system doesn't recognize it there for I can't use it, but I really want to upgrade my OS to Vista as originally my...
Here is what I suggest. I would go ahead and upgrade your OS. Windows Vista actually has worse performance than Windows 7/8/10. I recommend installing via USB flash drive. https://www.microsoft.com/en-us/download/windows-usb-dvd-download-tool
If you really can't get your hands on an upgraded OS. Here is a link that might help you to resolve your problem: No CD Rom drive in Device Manager No error reported by XP Windows XP
Otherwise I think it might be a driver issue. If you could supply the product serial I could point you to some proper drivers.
Jun 29, 2017 | LG GSA 4163B DVD±RW Dual Layer Burner
My dvd rom is showing up on my computer but it will not reconize dvd=s or cd's
Probably a failed drive. If Windows recognizes the drive, there really is no reason that any media inserted won't be recognized except bad media or bad drive. Probably the laser is gone or misaligned. There is no fix except to replace the drive.
Apr 22, 2010 | Acer TravelMate 223X Notebook
Dvd rom is not recognized
Not all computers detect DVD-ROMs. Look at the label on your laptop drive. If it says it supports DVD-ROMs, than you will be able to use it. If not, consider buying a DVD-ROM drive.
Nov 23, 2009 | Acer Extensa 5620 Notebook PC
I have a cd/dvd rom that will not recognize
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Sep 01, 2009 | Samsung TS-H492A (TS-H492A/WBGH)...
I have a Toshiba Satellite laptop with a SD-R2512 DVD drive that the unit will not recognize. It sees it in device manager and says that the drive is missing...code 39. I tried to delete it in that...
Seems like the DVD drive went bad.
My advice is try another DVD drive and install it on the same laptop. just to make sure the laptop is ok.
Please don;t forget to rate is this answer helps you in some way
Jun 25, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
Dell DVD Player Won't Open
turn the laptop off and then over you will see a thumb slider and possibly a screw remove screw (if present) slide ROM lock (thumb slide) and slide ROM out away from compy...and slide it back in and reboot make sure you here the "click" assuring that its in the LOCKED position again.
May 12, 2009 | Dell INSPIRON 6000 CENTRINO...
Dvd-rom not playing/recognizing dvds but plays cds
Yes your quite right, the solution to the problem is a new writer, although you have to get the same one if it's fitted internally to a notebook. You can update the firmware, thats not a problem, you may be getting confused with bios updates which are a knightmare. I assume you have tried the usual, uninstal and re install of the dvd drive, by uninstalling it in device manager on the cd/dvd drive line and click '+' sign, right click and uninstal, then restart pc to automatically install again. The cd recognition says that the drive capability to read and write dvd has corrupted andfailed, so really the only solution would be a new drive
Apr 28, 2007 | Toshiba SD R6012 (SDR6012-TA) DVD-RW...
Lenovo ThinkPad T61 Notebook Logo
85 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
