Question about Toshiba Tecra 8100 Notebook
Can't find the contrast button....help
Help
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 80 Answers
Http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su343646/tecra_8100_ug_20021219.pdf
might help you find what you need
Posted on Feb 10, 2009
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Pitney Bowes P700 has a a blue screen
I just spoke with a service rep because at startup, our screen would completely fill in. To set it back to default, unplug everything and when you re-plug it in, hold down the 4 button until it's done Initializing. This should reset everything. If you need to adjust the contrast, hit the options button, then it will be the 3rd button down on the left and the top button will become 'increase contrast' while the middle button will be 'decrease contrast'. Hope this helps!
Sep 14, 2012 | Pitney Bowes Postage Meter DM100i, DM200L,...
Contrast setting is too low, and the button is broken. Help!
Adjust the contrast permanently in full, if the control button in the front is broken you must adjust it inside. The brilliance has to controls in front and at the back inside ( the lower one) (the upper one is sharpness control) you can make there your desired adjustment.
Apr 27, 2009 | Computers & Internet
The menu that controls contrast, brightness ect is stuck on the menu and when i push the number 1 button on he monitor it does nothing but lock the osd. If i hit the down button the contrast will move down...
Try pressing the number 1 again. It should exit the OSD. While the screen is stuck with the OSD. Press the power button (blue) and push to turn it on again.
Hope this helps.
Mar 15, 2009 | ViewSonic VX924 19" LCD Monitor
Contrast and Brightness require adjustment
hi im josh in cebu phils. Maureen may i help you? If it happened yesterday that the contrast box keep on coming. there's a problem in your monitor.so try to check the buttons if covered with dust cleaning may solved the problem.Maureen if you have the manual use it in adjusting the resolution and if you dont have try to press the button mark + or increase just press both of the to the brightnest as posible so that you may be able to proceed another action. thats all for now.hope i helped you.good luck.
Feb 26, 2009 | HP Compaq 1720 (Carbon, Silver) 17" LCD...
Need help with Compaq MV5500 CRT 15 inch monitor
hi there, your switch botton is failling, manual buttons on the front to adjust controls, do some switch test, replace micro botton switch. ty
Dec 26, 2007 | Gateway FPD2275W LCD Monitor
Need help with Mitsubishi 15
Try pushing the contrast button, and then some of the other buttons once the contrast menu is up. To control those menus you use the buttons on the front of the monitor, not the keyboard and mouse.
Nov 24, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Toshiba Tecra 8100 Notebook Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
