Question about Roomba Robotic Floor Bagless Vacuum
Roomba's deck height adjustment string broke
Is there any way this can be repaired? It is still attached on the body of the Roomba, but where it goes in the groove on the deck, that is where it is frayed. Is there any hope?
  • 4 Answers
You can solve this problem if you are on the handy side. I had the same problem and fixed it, allowing Roomba to live until getting an all-too-characteristic fatal brain problem later.
You have to open up Roomba and guage the original length of its string. You'll need to make a replacement and cut the first one off. The shaft around which the original rolled to adjust the height is where you must affix the new one. It's a bit tough and you have to be creative (like screwing the string into the chassis with your own screw after drilling a pilot hole) but if you get the length of string right it will wind and unwind just like the original.
I wish I could be a bit more specific but it's been a long time since I pulled this fix. If you're not a tinkerer, don't try it because it is a bit difficult. Best of luck.
Posted on Jan 27, 2009
Irobot roomba won't work
This message sometimes happens when it\'s jammed or caught. I would open it up and really clean everything out to make sure the brushes are not jammed. Also pop out the ball white/black wheel at the front and remove all the hair around the axle for this.
This almost sounds like something caught in the wheels and gears. String and the like can get caught in there. The easiest thing is to find the end of the string and try to unwind it in the direction reverse to what it caught in. I tried taking the whole Roomba apart one time, it was tough, so I don\'t recommend it unless you are very mechanically minded. FYI to everyone with a Roomba, I knew someone who expected theirs to pick up random dry cat and dog poop around the house. No vacuum can do this.
May 13, 2014 | iRobot Roomba 530 Robotic Vacuum
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Machine just rotates same spot in a circle
I just repaired my 530 roomba last night. I used a sewing machine brush and cotton swabs. On the bottom of the roomba there is a face plate with four screws. Loosen each of these four screws and remove the face plate. DUST EVERY OPENING YOU CAN SEE, but do it gently. Use NO chemicals. Then there is the area that holds in the brush and roller cartridge. Again, loosen those four screws and remove the corner brush's screw and completely remove that little brush. Then you will carefully remove the "case" holding the brush and roller cartridge.DUST EVERY OPENING YOU CAN SEE. Wipe all the silver contact points..plates on the bottom of roomba and one inside the brush and roller cartridge. At this point, I dampened a paper towel ever so slightly with some window cleaner and wiped and dried those contact points. Then using the brush attachment on my vacuum I gently went over all areas of the body of the roomba to dislodge even more dust. Once that is done, reattach all the parts in the reverse order of how you removed them. I charged my roomba overnight and this morning she was charged and worked as if she were brand new! I hope this helps. If my solution works for you,please contact FIXYA and rate my advice.
Nov 18, 2010 | iRobot Roomba 530 Robotic Vacuum
I have cleaned & cleaned this thing! It runs for about 2 mins & stops, says "Clean Brushes"! and now it's very noticeable it's not picking up well... but is picking up a bit. I take the dust bin...
Ok, this is a "Brush Height Adjustment" issue. It will probably work great on a hard surface but on carpet the brushes bog. If you've taken the unit apart it again. When you do, you'll see a String which allows the brushes to "Float" on different surface heights. Loosen the screw a little and pull a bit more string through. Re Tighten the screw and put it together enough for a test run. Now reset the roomba.To reset the Roomba, power the Roomba on, and press the Spot, and Dock buttons together for at least 8 seconds. Until it plays a tune. The clock, and any schedule is erased at this time. Try running the Roomba with the dust bin removed to see the brushes spin easier.
Second method, is taking off the bottom cover, and removing the battery. While it's removed, and not plugged into the charger, press the clean button for at least 20 seconds. This will erase the memory. Replace battery, and cover. Run the Roomba to see if the brushes start to spin. You can also remove the brush housing by removing the 4 screws and reseating it, to see if it was a bad connection, since you have the bottom cover off.
Mar 26, 2010 | iRobot Roomba 560 Robotic Vacuum
White & grey model Roomba is moving much slower on carpet since I replaced battery and filter, but moves normal speed on linolium. How do I fix this?
You need to adjust the "Brush Height String" The new battery is a bit heavier than the old ( by 10 ounces if you got the new battery) dis assemble the roomba and you will see a string attached to a screw which allows the brushes to rise and fall with different surfaces. Move the string 1/4 " and re tighten the screw. Good to go!
Mar 19, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba 560 goes in circles. appears lost
You have a locked wheel switch that needs to be cleared. You will need to remove the top of your roomba and find which wheel switch is clogged and clear it.
Mar 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Height adjustment won't work on Hoover windtunnel
In my experience, Hoover height adjustment are "stops" rather than being attached to an axel. Look for something that rould resemble a set of circular steps somewhere in the path the axel would take as it goes up and down. It is usually on the underside from the knob that sets the height. Each 'step' represents a height with the shortest step being the lowest setting from a certain perspective.
On some Hoovers, therte is a ratchet petal on the right side. The ones I have seen are similar in operation to the above.
Let me know if this helps you.
Sep 21, 2009 | Vacuums
The Roomba goes around in circles. If it
Are you sure it is 10 beeps ?
look in your user's manual, the beeps code is there with some
suggestions how to solve it
Have fun
Sep 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Bissell 6590 handle height adjustment
The handle adjustment knob part # is 2031095, the height adjustment wheel asm. part # is 2031330. You might try and see if you can order direct from them. If not, most repair shops should be able to order for you.
May 20, 2008 | Bissell 6590 CleanView Bagless Upright...
HANDLE height adjustment just broke and I can not find any place that sells it. Any suggestions would be of great help. Thanks, Mafiabella
It i called a detent lever, part # 2030052. Usually a repair shop can order this for you. Or you might try and see if you buy it online from them.
Roomba Robotic Floor Bagless Vacuum Logo
694 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
