My printer is connected to my computer and benn trying to print documents and other printable things and they will not print there is a flshing error message on my printer it says check paper or ink cartridge and there is paper in the tray and i just replaced the ink cartridges and the error still there one time the message went away so i tried to print again and still nothing so i dont know what elseto do
  • Anonymous May 05, 2009
    the printer say check ink cartrige
  • 3 Answers
Get a new printer u idiot!
Posted on Nov 21, 2008
  • la_kittykat Nov 21, 2008
    get a new printer u idiot!
    thanks it really helped
How do I stop printable on Envy Printer?
How to Stop or Manage Scheduled Printing - HP Customer ...
support.hp.com/us-en/document/c03181888
These steps are for HP Connected. Go to HP Connected, and then log in to your account. Click Services. Click Printables, if it is not already selected. Click the minus symbol ( ) to the right of HP Printables - Useful content delivered to your printer to see the Printables available on your printer.
Stop or Pause Scheduled Printables - HP Customer Support
support.hp.com/us-en/document/c03615542
Press the Down Arrow ( ) to select the printable that you want to stop or pause, and then press OK. Press OK again. The printable's Settings menu opens. Press the Down Arrow ( ) to select Turn off Scheduled Printing or a Pause option, and then press OK.
HP Connected - Remove ePrint and HP Printables in HP ...
support.hp.com/us-en/document/c03606868
Dec 29, 2015 | HP Envy 4500 e-All-In-One Printer, Copier,...
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
What is a PCL Error Press Set?
This is a somewhat generic error. It may indicate a problem printing that specific job (document). Sometimes a large or complex job can produce such an error such as a graphic intensive Word document or a large PDF.
You will want to first cancel any pending jobs.
Press Set on the printer.
Turn the printer off, wait 30 seconds, then turn it back on.
It doesn't hurt to restart your computer, too.
You can try printing the job again. If the same error is produced, try printing it from another application or from another computer. If that still fails, try printing the documents in smaller chunks. If the document is 100 pages long, try 25 at a time.
If the problem persists, you may want to consider how it is connected to your computer. If you are using a parallel port cable (fat cable with fat connectors on each end) you may want to switch to a USB connection. You will likely have to reinstall the printer using the driver CD that came in the box or by downloading the drivers from Dell's website. Though, if you have a newer operating system such as Windows 7 it may install automatically.
Mar 01, 2011 | Dell 3000cn Laser Printer
The printer prints a blank page with a line of gibberish in the upper left corner before it prints the real page.
Can you send me a "print to file" of the failing document.
At first blush it can be either of two things.
1) The preceding print job did not properly clean out the printer's memory.
2) The new print job, has data or a busted escape command in it that is being treated as printable data.
Send the print file to don.farr@hotmail.com and I'll read through the document header to see what's going on.
Don
Mar 02, 2010 | Dell 1720dn Laser Printer
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
How to print envelopes on my printer
Use The Recommended Print Area For the best printing results, adjust the top and bottom margins of your document to within the recommended printing area shown below. Click on the paper size listed for the recommended print area settings: A4 / B5 / A5 / 4 x 6 / 4 x 8 / 5 x 7 / Credit Card, Letter and Legal, Envelopes (DL / COM#10)
Caution: When printing is performed outside the recommended printing area, the top and bottom edges of the paper may curl, the print quality may deteriorate, or the printed side may be smudged.
The printer has both the recommended print area and the printable area, according to the paper size.
05sj00144_01.jpg Recommended print area: This indicates the recommended print area.
05sj00144_02.jpg Printable area: Although this indicates the printable area, degradation of print quality may occur.
Note:
  • Set Borderless Printing to print without margins.
  • In Duplex Printing, the printable area of the paper's header is approximately 2 mm narrower than usual.
05sj00084_03.jpg Letter / Legal
Envelopes ( DL / #10 )
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Printer is online and says ready but won't even attempt to print
Click on Start,
Go to Control Panel,
open Printer and Faxes
look for the Printer which is HP C5280 or any icon related to same,
Right click
Choose set as default
Close Everything
Shutdown your computer and Printer
Check and make sure that the USB cable is connected propely
Restart the Printer first and then the computer,try Printing some thing.
if this doesnt resolve you issue then i would suggest you to uninstall the printer software and reinstall and update it from HP.com.
Please let me know about the resolution
Oct 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
HP All-In-One HP C7280 (Ink Jet Color Printer/Scanner/FAX)
on that web page look if u have any thing which says printable version or printer friendly
try with that and check
Mar 07, 2008 | Office Equipment & Supplies
105 people viewed this question
k24674
jasbo
jasbo
