Question about AEG 24 in. Favorit 40310 Free-standing Dishwasher
Water overflow from AEG Favorit 420 dishwasher on filling
The dishwasher works normally.
The undertray is removed.
The machine is elevated so that it can be inspected whilst running.
It fills normally, but just before it shuts off the input, (this is audible), clean water flows from an outlet in a complex moulding on the left as you view the machine from the front. The flow ceases shortly after the water supply is shut off. The rest of the mechanism looks dry.
The filters are clean. Experience shows that if the fine gauze filter is not, a similar problem occurs, but this does not appear to the cause in this case.
  • phil_val_red Jan 10, 2009
    I have exactly the same problem with a AEG Favorit 44080i.
    As the inlet flow stops, a small amount of water comes out of a small clear overflow pipe attached to a complex plastic water distribution tank on the side of the unit. This is caught by th eflood tray in the base.
    Everything works normally but after 2 or 3 cycles the flood sensor is activated and the unit has to be tilted over to drain the water from the flood tray.
    I can't work out where the control of water to this small pipe comes from.
SOURCE: AEG Favorit 420 Freestanding dishwasher
i have 4220 and i replaced the drain pump, fixed, located underneath to right at the front
Posted on Dec 28, 2007
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 20 Answers
SOURCE: I need an manual in english for the AEG Favorit
try here. http://www.serviceforce.co.uk/pdf_search.asp
Posted on Jan 21, 2010
mastermaid
  • 502 Answers
SOURCE: AEG FAVORIT 443 Manual I need a manual. How to
Hi, I found the Favorit 443 manual here
Posted on Aug 19, 2011
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
I30 message on aeg favorit 50879 u
Activated Anti-flooding system, means water leakage in the buttom of dishwasher. Could be also: faulty Anti-flooding microswitch, floating sensor (styrofoam) blocked mechanically, wiring diagram, electronic.
Dado
Jun 17, 2014 | AEG 24 in. Favorit 40850 Free-standing...
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My AEG Favorit Sensorlogic Turbodry dishwasher is making 3 short continuous beeps which I understand means the leak prevention system has kicked in. Is there something I can do to reset or must I call a...
Open the left metal panel, if the white plastic tank is black at the bottom or is not clean: remove it, open it, clean it (make sure the water flows through properly) and put it back in.
Mar 04, 2010 | AEG 24 in. Favorit 80860iW Built-in...
AEG Favorit 665i. Lower arm does not turn
im not sure about this if the upper arm is working ok,because the lower arm gets the pressure first then sends it to the upper arm,if the water pressure to the machine is ok then the lower arm is at fault take another look at the lower arm something is not right with the lower arm.adrian;;
Jan 22, 2010 | Dishwashers
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
My AEG 18 in. Favorit 54750Vi has stopped working. It sounds as though it's going to start normally then starts to beep. When I open it the 'Rinse and hold', 'Normal 65*',and 'Intensive 70' indicator...
If for any reason (water leak)the anti flood device at the bottom of the washer is triggered it automatically stops the inlet of water via inlet solinoid and puts the washer in pump out mode. Check the float (polystireene plate with micro switch at the bottom of the washer). Dry any water and determine the reason for water and this should let water in again.
Oct 12, 2009 | AEG 18 in. Favorit 54750Vi Slim-Line...
AEG Favorit 60820 sensorlogic .30 code water problem
You can unclick the top part which gives better access to the lower part with the blockage. Hot water, pipe-cleaners, cable ties, bits of wire can all be employed to get the grease out.
Jun 06, 2009 | AEG 24 in. Favorit 60820W Free-standing...
Dec 26, 2007 | AEG 24 in. Favorit 40310 Free-standing...
AEG 24 in. Favorit 40310 Free-standing Dishwasher Logo
98 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
