Question about Kenmore 42822 Front Load Washer
Kenmore HE3 model 42822 flashes HF??????
Can you help?
  • sdwall Nov 27, 2008
    After getting into the machine I started to check out the water lines a lttle closer and found that the cold water intake screen was plugged clean it out and everything works great once again
  • 1,028 Answers
Probably fh sure drain hose is at least 30 insches from floor and fits loosely in standpipe to prevent siphoning also ckd all fill hoses for obstructions in inlet valve ends most likely problem is flowmeter remove top round object left side with 2 small hoses try tapping it this may at least let you know for sure it is problem even it doesn't flowmeter is most likely the problem
Posted on Nov 21, 2008
Elite he3 42832
the problem is the oil seal from the shaft to the tub,need to change it!
Oct 03, 2013 | Kenmore 42822 Front Load Washer
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Washer stuck
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 01, 2009 | Kenmore 42822 Front Load Washer
IT wont start washing
if it fills with water or has filled and wont go any further then suspect the door switch< latch assembly has switch> if it doesn't fill then possibly water valve not working,if neither of these seem accurate then please give more info
Apr 20, 2009 | Kenmore 42822 Front Load Washer
Door Seal
Just follow this link and it will explain how to replace the door seal:
This is a very simple repair, if you follow the step-by-step instructions. Take your time and if you have questions, let me know. I hope this helps you.
PS An alternative method is to work through the door with the front panel in place, but this limits access. To make things easier, it is strongly recommended that you remove the front panel.
Apr 13, 2009 | Kenmore 42822 Front Load Washer
My Kenmore Elite Frontloading HE3 is flashing a Sud, what do I do
apply a small amount of cooking oil imside tub ,, must use only HE deteregent if you are ,,, maybe too much
Jan 01, 2009 | Kenmore 42822 Front Load Washer
F06 error
Check the drain pump. There may be something jammed it it, causing it to overload, and bringing up the fault code.
Oct 25, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 42822 Front Load Washer Logo
276 people viewed this question
Sal De
 Brian Main
Brian Main
