Question about Whirlpool LER4634J Electric Dryer
My whirlpool dryer is dead
I went to put a load of wet clothes in the dryer and when I hit the start button, it made a click noise and that was all folks it hasen't made a sound since the breaker is fine the dyer will not turn on.
  • 2 more comments
  • crashd Nov 23, 2008
    I touched the back of the dryer and got shocked... it shutoff and nothing... the breaker wasn't tripped (I reset it anyway) nothing.
  • mikebrandi Dec 02, 2008
    I have the same problem. I checked the thermal fuse and they were ok. After taking further voltage reading I replaced the motor but I still have the same problem.
  • alfjrkh3 Dec 11, 2008
    I have same problem, i replaced motor, motor switch, and timer switch ad still have nothing
  • Bennie Davis Jan 11, 2009
    I have a Whirlpool LEN1000PQ0 Electric Dyer which has the same problem. Dyer was working, when I pulled the clothes out and put in another load, nothing. The dyer would not work. I checked the Thermal fuse and shows .000 ohms. Is this the correct ohms? This would be the second thermal fuse I've replaced.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Most newer dryers have a thermal fuse link which prevents them from producing heat if it has overheated due to lint build up. Safety! Remove the back of the dryer after you unplug it of course. Look for a white, two connector, block about 1/4 by 1-1/2 inches, mounted to the back of the heat transfer duct. Remove both of the wires from the the connectors and test the fuse for continuity. Multi meter needed. This should show 0 Ohms. If there is no change on the meter than this fuse is bad. Most any appliance parts place will have in stock. $12 - $15 Clean out as much lint as posible from the exhaust opening with a vacuume and reinstall the back panel.
Posted on Nov 24, 2008
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Maytag Neptune Dryer MDE3000AYW. Replaced pulley and arm (pulley was seized to it), rear drum wheels, front drum glides, belt. Cleaned throughly inside. Worked like a charm for about 6 loads. Went to hit...
I'm guessing that your belt my have been misaligned, which means, no problem!
But, I recently had a machine that had a motor that would not turn, only hummed. I vacuumed the lint, then blew the lint out of the motor with a compressor, and vacuumed again. It still needed a push start to get the motor turning, but it starts on its own, now. So, if you have a lot of lint buildup, it can eventually stop the motor
Mar 06, 2017 | Maytag Dryers
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
My dryer makes a load clicking or grinding sound when I start it. It appears to happen when I put heavy wet cotton clothes in it. If I reduce the load it will not happen. The dryer is 18 years old and has...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Mar 27, 2011 | Whirlpool Dryers
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
Can I make the water level on my whirlpool duet washer higher?
its because of the design of the machine they are water efficient.a front load uses any where from 15 to 18 gals. compared to 40 to 50 gals.for a top load. they also have a higher spin rate than the top loader,therefore making your close dryer and having a less drying time in the efficient too!!
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer won't start F30
well the sensing light will stay on till it feels wet clothes against it if you in auto dry mode it says it wont start without feeling wet clothes against the silver bars in the vent housing it says it will run in manuel mode even if it doesn't feel them pull the top off the dryer and on the right hand side is a tech service sheet in a plastic bag see what it says
Mar 30, 2008 | Dryers
Whirlpool Model LG7681ZSN1
check the door switch if it is working then a broken belt can cause this problem let me know how you make out
Sep 13, 2007 | Whirlpool LGB6000KQ Gas Dryer
Whirlpool LER4634J Electric Dryer Logo
190 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
