Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Built-in speaker in Mac doesn't work (red light!)
I plugged a headphone in my Mac but when I unplugged it, the sound stopped and a red light shine from the jack.What should I do?
I took a safety pin and put it in the notch inside the headphone jack input. notch is located at 12 o'clock about 1/8th inch in, (this is an important step, other steps are no good until red light is off) the red light went off (Be patient this step may take time) still no sound, I then went to Audio MIDI setup (Should be located in Applications/Utilities), go to Audio in menu bar (at very top of computer screen) and selected 'open Aggregate Device Editor,' clicked on the + to add a device I then had a few options show up in the lower [Structure] portion I clicked on all the 'Use' boxes and the built-in output bubble selected done. I then Selected Configure Speakers in Audio MIDI setup and I can test my left and right speakers individually, they put out a fuzzy test sound, pressed done when finished. They still didn't work so I set Default out put to the Aggregate Device I created, then turned on Itunes and it was working fine I just could not control the volume from the F3, F4, & F5 buttons so I went to sound in system preferences and made sure the built-in Output option was selected. I was then able to control the volume. The red light in headphone jack input may come back on if anything is inserted inside, just mess around with the notches inside till it goes off. Hope it works as well as it did for me. Good luck and please feel free to quote me and share this solution with others.
Posted on Jan 22, 2009
  • gustavo_fors
    gustavo_fors Jan 19, 2013
    Hi, I'm having this problem since I installed Windows on my macbook via Bootcamp. The red light only shows on Windows. When I'm on the Mac OS the red light doesnt lit up but the speakers doesn't work, only external sources. On Windows, my thunderbolt display sound works but not the headphones. Do you have any clue what this may be?
  • 37 Answers
I had this problem once too, first off, plug the headphones back in. Now gently remove it, if this does not work, go to settings>sound>output>built in speakers
Posted on Nov 22, 2008
  • 11 Answers
This is a known problem with some Macs. The port is used for both headphones and for a video+audio plug. The Mac thinks it's detecting the wrong one.
Some discussion of this problem here: http://discussions.apple.com/thread.jspa?threadID=1011421&tstart=0
If you're under warranty, it's worth taking it in for repair. If not, some people have fixed the problem by plugging in a different set of headphones, or by gently(!) probing inside the port with a toothpick to trip the sensor.
Posted on Nov 21, 2008
Solution #2 worked for me with the toothpick! I had to probe a bit to the right, more at 3:00 for me than 12:00- still grateful for all of your answers!
Posted on Dec 12, 2009
  • erica784 Dec 22, 2010
    Using a paperclip end worked, the magic spot was at 9:00 for me. Once I had hit the right spot the volume can on immediately. It took about 5 careful attempts. Thank you!
I had a problem buit in speakers on my unibody macbook .. ie after the dual boot windows xp in boot camp built in speaker sound is not detected, such as noise, when booting in OS X the speaker's voice sounded very clear, what I should do. please
Posted on Mar 13, 2010
Guys- I have almost the same issue. My left build in speaker just made a cracking noise while I was playing around and recording my voice on Garageband. Anyone know how to fix it? I didn't use any jack to record my voice or anything. :(
Posted on Oct 22, 2011
My macbook air does not play any sound anylonger, it suddenly stop working and a circle with a line inside appears when I try to increase or decrese the volume...?
You laptop may have sound prefs set to external speakers, or if there is a red light coming from the headphone jack. the mac thinks the headphones are still there.
Plug in and unplug the headphones an see if the red light goes out. may take a couple of times. Be gentle
Aug 17, 2010 | Apple MacBook Air
Hi there, i cannot get the sound working. when i click onto the output section in sound, there is only 'digital out' and not 'built in speakers'. how do i fix this? thanks
Is there a red light glowing from the Headphone jack?? If there is, stick a toothpick in there and wiggle it around until you find a little toggle switch in the back, toggle it, and the red light should disappear, thus giving you back internal speakers, and use of headphones!
Aug 08, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
My ipod wont play sound aloud, it only works with the earphones, it used to work??
The speakers may be damaged, if you think water damage is the reason that the speakers are broken then follow these steps,
1. Unplug headphones. 2. Take you iPod to a dark place i.e room with light off. 3. Take a flash light and shine it in the headphone jack 4. Look inside the headphone jack. 5. If you see something red it is likely that your iPod got water in it and the speakers are shot.
Hope this helps, --Kaleb--
Nov 16, 2009 | Apple iPod touch
Sound not working on my macbook
try blowing hard into the output socket, then plugging and unplugging your headphones.
Aug 17, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
No sound on macbook
That's a problem with the sound card. Had the same issue on a new MB and called Apple. Ended up sending the MB and Apple replaced the sound card and it has been working well since.
Jun 09, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Speakers don't turn back on after removing the heaphones
The way you described convinced me that your audio driver is OK, but the sound can be heard through the headphone only. If this is the case then you have a mechanical failure (metal fatigue) on the head phone jack assembly.
I consists of two DPDT switches ganged together in a small housing with have 3mm jack on it. The leaf spring contacts failed to make after the headphone plug is detached. Only skilled technician can remove it from the PCB then sold an new one in.
Jun 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Dual 2.5 GHz PowerPC G5 sound output
This is just how it works. The headphone jack on Macs is dual-purpose. If you plug in a mini-Toslink cable (like you have) it automatically sends the sound through that & increases the computer's volume to maximum. When you unplug the Toslink, the laser will still shine for a brief moment (but then it does go off). So, there is no way to keep the Toslink plugged-in AND utilize the built-in audio at the same time.
Mar 27, 2009 | Apple Power Mac G5 Desktop
Problem with speakers, Mac laptop MacBook 13" white
Have you made sure that the sound options in system preferences are all set, and not muted? Open system preferences, choose sound, go to the output tab. Make sure it's not muted or something silly.
If that's not it, and you're mechanically inclined, you can try opening the mac case and see if the speakers are disconnected. Although, I doubt they are unplugged.
Steven
Sep 17, 2008 | Computers & Internet
Macbook 2 ghz white no sound
this has been answered, just stick something small in the headphone port, best to save money, or take in a local apple store.
Jun 03, 2008 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
HAHA i had the same problem so here is what i did...i stuck a head phone plug in the jack and smacked it a couple times and bam it works....i would suggest doing this if your lazy otherwise go to the apple store because obviously somthings not right in your laptop.
Aug 23, 2007 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
11,474 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
