Question about Whirlpool GD5SHAX Side by Side Refrigerator
Freezer Light Light in Freezer is not working. Replaced the bulb with one we verified is working, but it didn't work in the freezer.
  • 1 more comment
  • Tammy Miiller Dec 20, 2006
    I fixed this problem by Unplugging the refrigerator and plugging it back in. The lights all work now. Thanks
  • Hawaiki Dec 30, 2007
    My refrigerator light is OFFmost of the time. When I play with the on/off switch, sometimes the light stays on. What's should I do?
  • ted1998 Jan 12, 2008
    Light did not work. replaced it with new bulb that is good. Still dosent woprk.
  • 237 Answers
You can try tapping the light switch (snapping it on and off) to see if that helps but this usually would require a voltage checker or multimeter to test for 120 volts at the socket of the bulb. If you're not comfortable with electrical stuff, don't stick test leads into a live socket... Basically you will somehow need to determine if the switch is the problem by pulling it out and testing for voltage, etc. Some models have a thermal overload to kill the power to the light if it should stay on for some reason, that could be bad too if you have one installed. This type complaint is hard to resolve unless you have the test equipment to explore where power is or is not.
Posted on Dec 20, 2006
Light bulb is not working. how to change it and what kind of bulb is it model: FKFH21F7HW
Good Afternoon Rose, I am happy to assist you!
Before replacing the light bulb in your Frigidaire freezer please confirm that the temperature control is set in the OFF position and unplug your appliance to avoid electrical shock. Typically, you may remove the light bulb by turning it counter-clockwise. The old bulb can be replaced by an equivalent watt bulb (part number is 216988100) available either from part distributors or hardware stores. I hope this information helps to some degree!
Feb 25, 2014 | Frigidaire FKFH21F7HW Freezer
Both of our light bulbs on top burned out the same time/day. Model # GLRT218WD My husband changed one light bulb and it didn't work. Does that whole piece come out of the top, where the light bulbs...
Check the door switch. Alot of the time when the freezer door stays open it creates condensation and than when you close the door is can freeze the door switch closed so the switch thinks that the door is always closed. If you need further assistance or this does not cure your problem please reply.
Aug 01, 2011 | Frigidaire Gallery GLRT218WD Stainless...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Whirlpool Refrigerators
Replaced 30 watt bulb in refrigerator section with 25 watt bulb still will not light otherwise working well, my be switch . freezer section light works
Either the door switch or the light socket is bad. Disconnect the refrigerator and pull the switch out and test it with an ohmmeter for continuity.
Jan 06, 2011 | Samsung RB2155SH Bottom Freezer...
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Feb 11, 2008 | Refrigerators
FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Jan 22, 2008 | Freezers
Whirlpool GD5SHAX Side by Side Refrigerator Logo
197 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
