Question about Honeywell Programmable Thermostat Heater
Honeywell PRO TH4110d Prog Thermostat not responding
My brand new thermostat and heating system will not stay on long enough to heat up my home. It kicks the heat on for about 3 minutes (about long enough to raisethe thermostat 1 degree), then it shuts it off (far from the targettemperature) and will not heat up again unless I manually switch theheater on and off.
I tried changing batteries in the thermostat and have read the operating manual cover to cover trying everything.
  • Anonymous Nov 23, 2008
    I have a honeywell thermostat FocusPRO TH6110D1005 which will not stay on until it heats the room.  The temperature is at 62 and I set the heat on 74 and it turns on but doesn't ever get warm.
  • 27 Answers
Cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
Posted on Nov 26, 2008
After installing this thermostat on my home heating system, it cycles as should, but furnace kicks back in after a minute or less.
if furnace comes back on in less than a minute , How does it maintain a constant temperature ? or does it ?
Jan 18, 2016 | Heating & Cooling
I have an evcon furnace that was put on brand new about 5 years ago. I have noticed that it doesn't seem to be kicking off and it doesn't seem to be heating my home either. A line was kinked last year...
This going to be little lengthy. The fan can be on from two reasons. If your thermostat has a fan switch, it will say ON or AUTO. Put it to AUTO. Turn your thermostat to its lowest setting and wait 3 or 4 minutes. If the fan stays running, the problem is in the furnace. Newer furnaces have big circuit boards that control all its functions. The fan automatically starts after a factory set period of time (about 45 seconds). Try a HARD reset to get all the furnace functions back to normal. Turn your thermostat as low as it will go. find the breaker or fuse that serves only the furnace. Unscrew the fuse or turn off the breaker for a good minute and replace/reset it. If the fan starts right away, the board is probably bad. PC relays often arc together and the entire board will need replacement. If the fan is off, turn your thermostat way up and see if the furnace lights. The fan will probably restart in a minute or so as a normal function, heat or no. If the furnace does not fire, Let me know and I'll tell you how to check that switch that was replaced.
Oct 24, 2013 | Heating & Cooling
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
The heater does not stay on long enough to heat my garage. it will come on for 3 to 5 minutes and shut off. it comes on again in 5 to 10 minutes for 3 to 5 minutes again. the heat is good when it runs....
You could tripping the high temp limit this will be located near the heat exchanger When it shuts how long does the blower motor stay running? Do you have a meter?
Dec 15, 2010 | Fahrenheat FUH5-4 Heater
I have a TH8000 Vision Pro. It is controling a
Whats' so hard is the Honeywell thermostat has a built in 1@ differential. It is not adjustable.
You might ask your installer about a time delay relay installed in the furnace to break the thermostat heat wire (usually white wire).
Most time delay relays are 90 seconds. But that might be enough to reduce the furnace cycling.
Dec 15, 2009 | Honeywell Programmable Thermostat Heater
Heat kick on then off
Check the thermostats. They work when cold but will not reset once warmed up.
Eric
May 27, 2009 | Kenmore Dryers
Goodman heats but defrosts turns on before desired temp.
Yes. The defrost cycle of a heat pump is actually turning on your airconditioning to heat up the condenser to thaw it out. During this cycle your electric strip heaters "should" be adequate enough to compensate for the a/c being on. At about 30 - 34 degrees outdoor temp there is not enough heat in the air to to adequately heat your home with the heat pump only. Some technitions will use an outdoor thermostat to turn off the heat pump when it is under 34 degrees outside. If you are to cold when its under 34 degrees intall more electric strip heaters.. But if you do this your electric bill may go up significantly.
Welcome to the wonderful world of electric heat pumps (lol).
Good luck.
Mar 29, 2009 | Goodman GMS90703BXA Heater
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Honeywell rth7400 keeps turning furnace on
check your heat antisipator setting make sur eit matches your tpye of heat. also, do you have a 2 stage heating sys?
Nov 21, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
833 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
