I need to replace the front door seal on my GE front loader
Model WBVH6240FWW-- I purchased a front door seal and need directions to install. I read that it takes patience and time, but would like some direction.
Thank you.
  • rlupetin Nov 24, 2008
    I have purchased the replacement gasket for this washer,but I need instructions for how to replace it. It seems that I need to replace the front panel. I can see the screws that I need to loosen, but I'm unsure as to how to do it. Anyone have any advice?
Go to type in the model and look the prt up and when u scroll down click on it to view and they should have a video on how to replace the part.
Posted on Dec 13, 2010
GE front loader leaking new door hinge on left side... It is not down spout but that the gasket didn't contact door on that side allowing leak door will push .5 -1 inch on hinge side. M#Wbvh6240fww
Recheck the door hinge install. Sound like the hinge is not installed properly leaving a gap on the hinge side. There are sometimes notches or hooks on the hinges that need to be in holes or cutouts on the washer body for proper fit. if the hinge is not in the holes right it will stick out from the body and leak.
May 16, 2015 | GE Washing Machines
How can i order a rubber seal for my ge front loader washer wbvh6240fww
I found the best site was Sears parts site. They usually have the schematics so you can order the right part and is you may need another.
Jul 02, 2014 | GE Energy Star WCVH6260F Front Load Washer
GE Profile front loader washing machine is leaking front of door, believe the problem is the rubber washer ring, however can this be replaced?
Hello, this is usually the door seal, most machine incorporate a one piece combined door seal and outer drum seal(often just called a DOOR GASKET), the door seal are put in on the front panel first in the factory, then the drum assembly is put in and the seal pushed over the outer drum. This means a lot of stripping down has to be done just to replace the drum to the door seal.
Jun 14, 2010 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
GE front load washer model #WBVH6240FWW leaks when filling at top and drips down side of front ballancer
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Sep 27, 2009 | GE WBVH6240F Front Load Washer
Ge washer
remove top cover by 3 screws on rear then 3 screws in plastic control panel back. remove screws holding console on, lift up to remove, screw in dispenser area as well. remove lower kick panel and lower front panel screws. remove door lock screws and wire clip around boot. remove 2 upper front panel screws. there is another wire clip around boot at tub.
Apr 22, 2009 | GE WBVH6240F Front Load Washer
I have notice this problem with a lot of front loaders. I would check the manufacture warranty to see with is covered and if you bought an extended warranty, use it, keep your receipts for your previous purchases.
Dec 11, 2017 | GE WBVH6240F Front Load Washer
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
