Here is a complete teardown video from Youtube... it's a difficult project for sure!
https://www.youtube.com/watch?v=qcCB94volbA
If you do still have some battery life left, use some of these tips to reduce battery consumption...
1. Use cinema display mode when not in use (with current firmware installed, simply activate your screen and then press your button twice in a row). This will keep the screen off for a period until you deactivate this again (press once to activate screen, then press twice quickly again to deactivate cinema mode).
2. Dim your display. The screen is nice when it's bright, but this is a major reducer of your battery. Dim your display to what you need and watch your battery last.
3. Activate airplane mode. Also found in your settings, this will disconnect your bluetooth connection to your phone, but it will also extend your battery significantly.
4. Make sure "ambient screen" is turned off. This is also in your settings. Leaving it on will allow your screen to dim to a lower setting when inactive, rather than shutting off. It allows for a bit more eye candy when being worn, but does reduce battery.
