Question about Sanyo DP42746 42 in. Plasma Television
Hdtv has no power at all.
When unit is pluged in,and turned on it dose not function.
Posted on Nov 29, 2008
Looks like the remote is faulty, a replacement remote may fix it.
Aug 29, 2008 | RCA RTD210 System
Try using compressed air to clean terminal block plugs (specially mA plug) - something is stuck there and unit thinks that you have your leads connected to mA and setting and will beep if you turn knob to any other function.
Jul 19, 2013 | Measuring Tools & Sensors
We undertake annual maintenance contract for Sanyo VRF air conditioner at standard charter bank nepal ltd., we have found the AC dose not function as well now. The fault shows as E4 on remote control. Now...
E04Indoor seeing error from outdoor. Qty of i/d units connected are less than qtyset. Check; all i/d units are ON,
reset turn off all units wait 5min power up
Jan 28, 2011 | Heating & Cooling
Garnin 260w slide switch will not turn off unit.
Try resetting the unit and also charge it using only the wall charger overnight. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES PLEASE Take the time to vote me up this is my only reward for trying to help. Thanks
May 01, 2010 | Garmin nuvi 205 GPS Receiver
Lost the Copy and Fax Receive Function
Hi Vic,
I'm sorry to say your fax machine has a bad LASER unit. A laser error code will stop all print functions. The laser units are no longer available.
Sep 15, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
Remot control key is not communicating with car at all.
It is possible that the receiving unit on the vehicle is not operating properly. Whether that means a broken wire, bad circuitry in the receiver, or other problems it could the case, BUT more often than not, the key/remote was exposed to some kind of magnetic or high power field, effectively remdering the unit useless. Strong magnets, electromagnetic fields or even staying to long on a department store demagnetizer could lead to these problems. Go to the dealer and be prepared to take the hit, a replacement coded key can run several hundred dollars, but unless you swapped the battery and happened to get a bad new battery, than the dealer is the only solution, I hope this brief explaination shed a little light for you in the future.
Feb 24, 2009 | 1999 Mercedes-Benz E-Class
My tv wont turn on all it dose is beep when i pluge it in
If you look on the back of the set, there will be a chasis # probably a CTC169 . These sets usually need to have the power supply repaired. These are great sets and have an awesome picture. There is a kit,I which is available to service technicians which will repair the power supply in most cases. If you can find a good local technician , they should be able to repair this problem for approx $125-150. if you have further questions pertaining to this set , I will be happy to advise you. I probably have repaired a coule hundred of these sets. This is one of the few old crt sets that are worth fixing. Scrivitron
Jun 24, 2007 | Proscan PS32600 32" TV
Sanyo DP42746 42 in. Plasma Television Logo
85 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
