Question about Karcher 2500 PSI Pressure Washer
I have a troy built snowblower that has sat for 7 years.
My snowblower has sat for 7 years without running. i tookthecarberatour off and cleaned it. now, when i start it, the enginesurgesand no matter how much i adjust the carb i can't get it to runevenly.any ideas?
  • Bojanglesmm Dec 19, 2008
    1 year old troy bilt burned off gas in summer. but now primer won't prime think i'm getting no gas. is a line clogged?
    Novelist:
  • 185 Answers
Hi roaddoctor86; I suspect that your carb is the source of your problem in the fuel system. I always drain the fuel in my 2 cycle and even 4 cycle engines and then start them and run them dry, before I put them up for the winter/. I would suggest you drain the tank or at least take most of the gas out and then add a can of gas treatment/solvent and see if that helps. Something like Heet I think is one product.
Hope this helps good Luck Loriongh ps Please leave a rating if appropriate Thanks
Posted on Nov 21, 2008
    Sniper:
  • 87 Answers
Hi roaddoctor86,
I aggree, you do have a carburetor problem, Loringh gave great advise for preventive maintenance but the damage already is done to your carb. You may be best of by just buying a new carb to get your snowblower working again. The old carb may need complete refurbishment. I believe just letting it sit in some sort of carb cleaner does not do the trick, I tried that myself and the carb still did not work right.
I tried cooking it in distilled water for an hour and still did not help, save yourself the aggrevation and just buy a new one and your back in business.
Hope this helps
Posted on Jan 11, 2009
My troy built snowblower 24.4 will not turn over it starts and stops has never been used since purchased it starts then immediately stops could the choke being open all the way be the problem
Posted on Feb 11, 2010
Where can I get starter parts for my Troy built snowblower
from any mower shop that sells parts for the make of engine used
( honda, B&S, Tecumseh, etc ) all you will need is the engine make and serial number to identify the parts
May 04, 2017 | Troy Garden
Troy built storm 2890 snowblower slow in reverse
There is an inspection pan on bottom of snow blower remove the 2 or 4 bolts and drop pan
inside you will see an aluminum wheel (drive wheel) also a rubber faced wheel whitch runs on the aluminum wheel at a right angle (like a needle runs on a record on a record player.
Clean plate and rubber wheel using brake clean to degrease surface .
Also there is an adjustment to move the rubber wheel farther to the left for more reverse speed but in doing that you might lose top speed forward.
Mar 02, 2015 | Garden
How come my troy snowblower stalls when I move the choke switch from choke to run ?
Most likely issue is dirty carburetor. Dissasemble and clean with carb cleaner or sea foam (let parts soak in it, if possible), reassemble. Could also be head gasket, but less likely.
Feb 17, 2015 | Troy Garden
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Snowblower blowing smoke
probably oil seal or weak gasket engines build up pressure if theres a weak spot on gasket or seals it will find the spot .it can also be the pcv valve ,pollution control valve
Dec 15, 2013 | Troy Garden
Snowblower problems
www.troybilt.com/equipment/troybilt/snow-throwers
Dec 15, 2013 | Garden
My troy bilt horse has serial number 544253, can anyone tell me what the model number is and what year it was built? Thanks
if you have a B&S engine look at the frist two numbers on the code. thats the year of the engine and more likelyof your unit, As long as the motor has'nt been replaced. I'll checked on your serial number did'nt find a model. If this is an old troy built I'll have to call tech support. also I need to know what engine 4, 4.5, 6, 7, 8, hr power, and the name of the teller. MTD now owens troy built.
Oct 17, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Pony only runs with chocke 98% closed
Most likely the carburetor jet is still clogged after sitting for years with fuel in it. Putting injector/carb cleaner in the fuel tank may help, but if not, the jet needs to be soaked some more -- or replaced.
Follow mixing proportions on the label for injector cleaner.
May 27, 2009 | Troy-Bilt Pony Garden Tiller
Karcher 2500 PSI Pressure Washer Logo
310 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
