i recently had a very strange incident with my dvd burner. A cd exploded inside. I managed to clean everything up and remove all the broken cd parts, everything seemed to be in place. Only problem is that as soon as i start the pc the dvd tray comes out and it just will not stay inside, i have no clue whatsoever as to what it is. Please i need suggestions.
this problem can happen if tray-in sensor not sense. their r a small liver which press tray in sensor automaticly when tray stay inside. liver and sensor location is near emergency exit hole (when u use a pin for emargency exit actually u press this liver then it release try-in sensor). check this liver and its path any pice of cd is their or not. (to check open ur drive cover. to open it at first use emeargency exit hole to open tray then open cover)
a plastic washer has come loose on my NEC IS - T C3 CD/RW. I don't know from where. It's 5/8"...
(More)
a plastic washer has come loose on my NEC IS - T C3 CD/RW. I don't know from where. It's 5/8" inside dia. and 1' outside diameter. I have the box open.
I am having problems with my sony dvd burner dru800a I try to burn and says burning failed power...
(More)
I am having problems with my sony dvd burner dru800a I try to burn and says burning failed power calibration error
i have my player in an external enclosure and only recently when i plugged it in and the red light...
(More)
i have my player in an external enclosure and only recently when i plugged it in and the red light comes on...the eject botton is non responsive and it stops there
