Question about Samsung TXJ2567 TV
Samsung TXJ2567 long wait for picture
I'm glad you guys are here. Our Samsung (Model #TXJ2567, when switched on, has been taking longer and longer for the picture to appear. Once we get the picture the video is as clear as new. Whether the TV has been off for the night or turned-off then on, it is taking an hour for the picture to appear. I would appreciate any suggestions as to what the problem is. Thanks. Ed
  • Anonymous Jul 02, 2008
    straight line across screen, no picture
It is probably the CR socket or just cold solder
Posted on Feb 06, 2007
I have a very similar problem on my DTQ-27S2FC. This doesn't seem to be a tube problem, because the sound doesn't come on either. The only thing that works is the relay feeding main power. The problem seems to be that the supply feeding the 9V and 5V circuits is very slow to get up to required voltage to operate logic circuits. supply feeding ~12V to these Zener regulated? supplies starts at around 4V and slowly builds - when supply reaches about 11V the sound comes up the picture blips in. Once up the picture is very good except when a bright white scene is on, then the picture pulses. I've only had the set apart long enough to know I need to find some schematics. Or find a suggestion of where to look for the supply source problem. Thanks, John
Posted on Feb 05, 2007
    Sergeant:
  • 308 Answers
That is usually indicative of a weak picture Tube. If the set is over 8 years old, I would consider replacing it. Otherwise, a repair shop may be able to restore the picture for awhile longer.
Posted on Dec 20, 2006
4 Suggested Answers
SOURCE:
  • 2337 Answers
SOURCE: Samsung DLP TV shuts off
First thing I would suggest is to check and make sure that the cooling fan is working properly. The lamp may also have an intermittent failure as well.
Do a visual inspection of your lamp. In your case check for a fogged condition. If the failure is intermittent, the lamp will look fine to the visual check.
The newer TVs have blink codes that can be use to determine if the lamp is defective. Check for the LEDs on the front panel blinking and count how many and the time intervals they blink.
If you need any further assistance, let me know.
Posted on Feb 25, 2008
  • 12 Answers
SOURCE: No picture when TV is turned on, sound is OK
try to look at its circuit board and look for cold solder or loose solders usually solders with crack,they might be the problem,i dont think its the flyback coz you have audio.try also look at its picture tube at the back tru the crt if the filament is ok or it may also have loose connections
Posted on Jan 13, 2009
  • 7 Answers
Hello All, I may have an inexpensive solution to your problem. I had the same problem with my TV as well. It would shutoff by itself about an hour after it was turned on. The when I would turn it on again it would shut off after 5 to 10 minutes. Finally I got fed up. I knew it was not my bulb because the picture still looks good. I did here a buzzing if I would turn the TV on right away after it would shut off. That was do to the bulb recharging itself. I noticed the TV was extremely hot in the back. So automatically I thought it was the cooling of the set. All post I read keep saying the TV would last about 2 years to a year after a service. Which would be right because (most) service repair clean out the units before installing new parts. What I did was I opened unplugged the TV from the wall and opened unscrewed the back panel door. I used my Air compresser and blew out all the dust inside. ( A can of compressed air should do the job if you do not have a compressor) I removed the bulb and blew out the dust on the bulb as well. I did not remove the bulb from the housing unit. After I dusted the bulb and housing unit I reinstalled it. I keep my home clean but you should have see all the dust that came out. The dust covering the components overheat the unit which causes it to shutdown. It has been about 2 weeks and have not experienced any problems since. All I can say is give this a try and maybe this will work for you. This will only cost you about 10 dollars and 30 minutes of your time. This is better that Hundreds of Dollar in repair.
Posted on May 25, 2009
Samsung 793S (Black) 17
On these older CRT monitors when you have that type of problem it indicated that the high voltage power supply is not putting out the right voltage to charge the picture tube. As the power supply gets weaker the time to show a picture will take longer and longer. It is not worth repairing the unit because parts will run much more than a replacement monitor.
Jul 19, 2012 | Samsung 793S 17" CRT Monitor
I have a samsung LE40R73BDX/XEU LCD TV which continually clicks and eventually switches on. The time it takes to function is getting longer. can you help?
the power supply board is going bad. sorry! if you google "samsung power click capacitor" you will see just what is wrong. Next time buy american, wait, there is no american made TV's
Aug 14, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung camera takes to long to trash pictures
The higher the resolution of the pictures, the longer it takes to delete.
May 10, 2010 | Samsung S860 Digital Camera
Turn on tv blue light comes on.screen stays dark .nothing happens .tv would come on after 10 minutes thenit started taking longer. now not at all.
Well first of all you can tell us the Brand and the Model number of your TV? and tell how old is your TV?
Anyway you can try to reset your TV first unplug (switch off) your TV for 24 hours and then turn it again........... let us know if further you have the same problem.......
Good Luck!!
Thanks
Jan 06, 2010 | Televison & Video
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Can't Send Text Messages on Samsung Muse from Alltel (prepaid). It says
wel 1 of 2 things could have happened.either the person who activated it didnt do it or it is taking longer to work.spmetimes it does take longer,if i were you i would call the place where you got it activated i had this problem myself once.
Jul 09, 2008 | Cell Phones
Samsung 32 inch LCD delay in start up
I had a technician fix this exact problem today it is the POWER SUPPLY the TV is not getting enough power to the main board, i have been searching for weeks and no one ever post a solution here it is guys get them fixed $200 only
Jun 14, 2008 | Televison & Video
Mp3 and camera doesnt work
try *2767*6263# worked for me but deletes all music and images recieved via bluetooth
Feb 10, 2008 | Samsung SGH-X830 Cellular Phone
Samsung TXJ2567 TV Logo
175 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
