Question about Electrolux UltraLux 2000 Bagged Canister Vacuum
Just powered itself off
It powered itself off right in the middle of doing my carpet. it will not turn back on. checked all powere sources throughout the house. vaccum just died. is there a breaker switch on the vaccum itself? thanks in advance for your help
    President:
  • 2,976 Answers
It will shut off if your bag is full. If you are cleaning up fine dust, it will give a false bag full indication. Take the bag out and carefully, shake it down to get the dust out of the filter layers inside. This will let more air flow through the sensor.
Posted on Jan 01, 2009
My power path pro advanced carpet washer stoped in the middle of carpet cleaning it started smoken a lil now it wont turn on
something burnt up will need a meter to check and test unit usually smoke is associated with a shorted component
Jun 25, 2018 | Vacuums
I have a 1 year old Hoover carpet cleaner . I went to use it today and it won't start. Everything seams to be in the right position. can't figure it out..
Dual Power™ Carpet Cleaner - Hoover
hoover.com/products/.../dual-power-carpet-cleane...
The Hoover Company
Rating: 3.5 - ‎84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
Hoover SteamVac Troubleshooting: Carpet Washer Loss of ...
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
Repairing a Hoover Carpet Cleaner ' ThriftyFun
www.thriftyfun.com/Repairing-a-Hoover-Carpet-Cleaner.html
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Jan 29, 2016 | Hoover Vacuums
Brush not rotating but have lots of suction on my dc18 slim
Take a good look to make sure roller not bound up with thread etc and at one end the belt (some in the middle is not broken) that drives the roller is intact---belt broken or seized up.
Nov 03, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
My filter queen just had the motor rebuilt last year and was basically a brand new unit when I got it back. It is not picking anything up now when I vacuum. The beater bar on the carpet attachment is...
It sounds as if you have a clog inside the "Power Nozzel". They mention that there are "no user serviceable parts within the Majestic® Power Nozzle" My advice would be to see if you can see a clog with in reachable distance and try to remove the clog. One way to check for a clog which may work for you is to remove the attachment and shine a flashlight on one of of the attachment and look through the other side and see if you see light, if no light, most likely a clog. Past that you might void the warrenty if you try and open it up the Power Nozzel itself. You may want to ask a Phone service rep about clog removal.
Jan 19, 2011 | Filter Queen Vacuums
My dyson dc17 amimal's main turbine head is not working, is there a reset button or any other solution? I don't think it is the belt!
Right next to the power switch is a switch that will turn on/off the beater brush. Push firmly on this button and see if that turns it back on. It will turn itself off if it has too much resistance on it from getting tangled in something like a long carpet fiber that wraps itself around the beater brush. Check and make sure it's not bound up by something and then press the on/off button for the beater brush.
May 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Power wash /powerbrush sprays the carpet ok ,but when empty doesn't fill up with any dirty water from the carpet .Is there anything I am not doing correctly
It sounds like the suction isn't working right. Check the dirt tank to make sure it is on correct and check the red plastic filter on the dirt tank to make sure that it isn't clogged.
Dec 02, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Difficulty vacuuming SmartStrand carpet
Wish I had a solution because we have the same problem with our Smartstrand. We have a Beam Central Vac put in our new townhome and it takes a huge amount of effort to push the power head forward. I have tried a couple of regular vaccum cleaners on it; same problem. The bottom of our power head has a black residue on it. ILike you, I am thinking there is something in this green product that accumulates on the bottom of the power head and prevents the power head from going forward smoothly. There must be other people having the same problem.
Help!
Jon
Aug 17, 2009 | Oreck XLS700A Upright Vacuum
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Wont turn on
Could be a switch or the power cord. Most likely the motor went bad.
Jan 10, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Electrolux UltraLux 2000 Bagged Canister Vacuum Logo
196 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
