Question about Refrigerators
Digital temp controls-stay out & no control of ref.temp.
I have a GE side by side and it is equipped with a digital temp readout and touchpad control. The problem is: the red L.E.D. (0-9) display is out, and the temp set touchpads do do adjust the temperature. I replaced the control board and this made no difference.
Respectfully,
Steve
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
  • 2187 Answers
SOURCE: Problem with ice dispensing. I
I am not sure if I understood the problem. Please bear with me as I try to provide solutions to common symptoms.
The Touchpad if it is not dispensing any water the issue may be the inlet valve may no longer be working correctly. This could be the faulty valve or no voltage is going through it cause it to not work properly. You may check the wiring for this one. The other is that the ice may have frozen.
The ice dispenser may not be dispensing ice because of a buildup of ice in the screw like piece in the dispenser. This prevents movement thus preventing ice to be dispensed. This may be caused by the freezer not cool enough since some ice will melt and eventually will turn to ice again but build up on the screws.
Posted on Jun 23, 2009
arikrom
  • 528 Answers
SOURCE: Original motherboard
Hi, When i change motherboard that got fried I change also the Temperture sensor Number: WR55X10087
it is under the cover on the right side
Posted on Jan 07, 2010
MNTECH
  • 1543 Answers
SOURCE: Hello I have
Roll the refrig out and determine where the clicking noise is comming from. If it is form the small rectangular cover on back, replace the main board (WR55X10942) located under it. If the clicking is comming from the compressor area (at the very bottom, behind the cover which goes all the way across the bottom of the refrig) then replace the relay (WR07X10086) and overload (WR08X10061) located where the wires attach to the compressor, and for good measure, the capacitor (WR62X79 ). (located just to the left of the compressor)
Posted on Jan 12, 2011
  • 116 Answers
SOURCE: I have a stainless GE profile PSS26SGPASS side by
HI has the temp held steady at 28? And do you notice if the fan in running in the freezer if you open the door do you hear a fan running, if you do not, then the problem is a bad control board located in the rear of the refigerator behind an small access panel this control board runs about 175-200.00 to buy.
Sean
Posted on Mar 26, 2011
GE stove JSP40BB has digital readout all lit up. turning off power did not reset it.
Unplug the range.
Open the control panel to access the clock control.
Remove the wires from the control for 30 seconds.
Replace the wires on the control and plug the range back in.
If this does not clear the control you will have to replace the control.
Jul 24, 2010 | GE Ovens
I have a Ge refrigerator (model # PDS22MIsacc) it seems to be running alright, but the temperature control panel will not light. we are unable to change tempertures.
you will need to replace the main control board located on the rear panel behind an access panel,this board controls all temps and digital readouts,when the readout goes dark this board is the culprit
Apr 27, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
Can't control the Temp. too cold/Ice-Machine over flow
sounds like you have a sensor problem or a open damper ,staying open,so it keeps freezing in the frig...call if need more input...michael..doctor airr appl.repair..843-384-8474...
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
My GE pfs22s1sss refrigerator is running but the temp panel does not display
Most likely the display board that controls the digital readouts has malfunctioned. WR55X10522 or part number 1170076. You may want to shop around and do it yourself to save a little.If you need assistance feel free to let me know, Thanks, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 17, 2009 | GE Refrigerators
Ge profile buttom freezer cold refrigerator hot
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Pitco Frialator Model 14R digital controller panel reads "P"
Your controller is in a program mode ! To exiit program mode you will need press and hold the P button for 5 seconds to exit programming.
Scoota
Dec 01, 2008 | Pitco Frialator SG14 Deep Fryer
Hotpoint oven
does the display go to 425 or are you putting a dial thermometer in it?is the new control doing the same thing as the old control?
Oct 23, 2008 | Hotpoint RGB745 Gas Kitchen Range
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
