Transfer belt error on samsung clx3160fn
If the transfer belt has to be replaced, does that mean that I have to replace the whole drum? Or can you just purchase a transfer belt? Is there a website I can go to to order one? Thank you so much for your help.
Linda
    Genius:
  • 2,120 Answers
You might check eBay or http://www.samsung.com/us/support/repaironline/supportOnlineServiceRequest.do
You just need a Transfer Belt.
Posted on Nov 22, 2008
    Novelist:
  • 188 Answers
Hi Lendalou,
The answer is no, you do not need to replace the drum when replacing the transfer belt. The part number for the ITB assembly for the CLX3160fn is JC96-03611A.
Before you replace it, you should probably contact Samsung and make sure that it is not covered under warranty. Print a report of your printer. This will show you your total page count. If the ITB has failed considerably short of it's expected wear life, they may replace it as defective.
As far as where to get a replacement other then Samsung, you can do a search of the part number on your favorite search engine and I am sure you will find suppliers.
Good Luck,
Cory
Installing samsung clx6220 image unit
See page 103 of http://downloadcenter.samsung.com/content/UM/201112/20111205134621713/EN/English.pdf. It looks like the clx6220 uses a transfer belt to transfer all the different toner powders to the paper.
see
http://www.genuinetonercartridges.com.au/genuine-samsung-clp-620nd-clp-670nd-clx-6220fx-clx-6250fx-page-image-unit-transfer-belt.html
The transfer belt unit is refered to also as the image unit !
Also each toner cartridge contains the OPC drum and is replaced when you replace a toner cartridge by the look of it.
You need a transfer belt to transfer the image to the paper and this is why they call it an image unit.
I am guessing that the transfer belt needs replacement !
Sep 08, 2014 | Samsung CLX6220FX AllInOne Laser Printer
Printer prints with red smudges
Sounds like its a magenta drum going bad. It could also be the transfer cleaning blade assembly, or the transfer belt needing replacement. Do you know if any of these items have been replaced. Drums usually last around 40,000 prints. Transfer belts 300,000 and the blade 100,000. Hope this helps.
Aug 22, 2012 | Canon imageRUNNER C3200 Copier
I have a Xerox Phaser 6100. I just replaced the imaging unit and the transfer belt. Now my copies are coming out with lines across the whole page. one page that I printed came out wiht all colored lines...
Try doing a "stop test." Stop the print process at various stages, and see if which component creates the defect.
For instance, if a print takes 20 seconds, during the first 10 seconds, the drum is generating the image to transfer to the belt. If the image is bad on the drum, then that is your culprit. If not, then see which unit creates the problem.
Also, what color is the line?
After the unit gets to the transfer belt, you should check the transfer roller and fuser.
Whit www.iteminconline.com
Jun 07, 2011 | Samsung CLX-3175FN Printer
How to fix transfer belt error in my samsung CLX3160fn
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Feb 27, 2011 | Samsung CLX 3160fn All-In-One Printer
How can i order the transfer belt for a samsung clx3160fn
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
3. Select Tech Menu
4. Select DataSetup
Nov 29, 2010 | Samsung CLX 3160fn All-In-One Printer
Says transfer belt error, do i need to replace or can i fix?
HI,
The Transfer Belt error is because it is not correctly installed or it is defective,if so it need replacing.
You can Pull out of the Drum Unit, open front door and take out the whole assembly
Then you can look on the Transfer Belt, You can pull it out,
CAUTION: it is difficult to get it back into position again if your not sure what your doing.
You can replace the belt for around $40/$60 for the item + technician fees
Please RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 24, 2009 | Samsung CLP 300 Laser Printer
Error message 457 on my ricoh af4106 copier
Hi!
This information might help you.
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer
belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803- 012)
4. Replace the belt cleaning shift clutch. (Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O
control board
Sep 19, 2009 | Office Equipment & Supplies
TRANSFER BELT ERROR
This error indicates that there is a problem with the transfer belt. Either it has failed, reached end of life ( it is a consumable item, just like toner, and needs to be replaced on occasion ), or just is not correctly installed.
Try reseating it first. Remove the imaging drum unit ( the housing that holds the 4 toners ). The transfer belt is the unit behind the drum that is inserted along the top edge of the drum cavity.
it can be a little tricky to get it in there correcty. Kind of hold it up against the top of the cavity as you slide it back towards its holder.
Oct 08, 2008 | Samsung CLX 3160fn All-In-One Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
An
Aug 20, 2008 | Samsung CLP-550 Laser Printer
Transfer belt error
Transfer belt error, this is cause by the OPC drum which connects the belt. Make sure the drum sit well with the belt else replaced the drum.
Jan 29, 2008 | Samsung CLX 3160fn All-In-One Printer
336 people viewed this question
jasbo
jasbo
