Question about Goodman GMS90703BXA Heater
GMP075-3 heater no igniter voltage
My Goodman GMP075-3 heater has no igniter voltage. The blower runs, thered light lites then goes out, then blinks 3 times. I've changed theboard, but still the same problem. The igniter ohms out ok.
  • 1,420 Answers
Check the venting for a restriction, check the condensate hose for blockage, check the pressure switch and hoses going to it. And make sure the small exhaust fan spins freely.
Posted on Nov 21, 2008
Goodman Furnace gms91155dxa not staying on. The system ignites, but shuts off after 3 minutes. 1 blink LED system light
100% sounds like an electrical problem, something is not allowing it to go into a duty cycle.
Dec 04, 2016 | Goodman Heating & Cooling
Heater unit will not ignite, will note fire up
Check your furnace by the electrical panel, there should be a blinking error light. Sometimes there is a legend to how many blinking lights means what. I had an issue with mine, read the code and it turns out it was hitting the high heat limit. Turns out my blower motor wasn't turning on. Replaced it with a spare and it was fixed. Find out what type of furnace, and google the name, model, and the words, 3 blinking lights. Does your furnace turn on at all? Does it start to go through the cycle then stop? This is the proper cycle of a furnace and what should happen.
Inducer motor kicks on, it runs for a little bit, about 3-5 seconds, then you should see a bright yellow glow, this is the igniter, shortly after, you should hear a click and the gas should start to flow, almost immediately it turns to a blue flame. Then your igniter should turn off and the blower motor start up.
Mar 02, 2011 | Goodman GMS90703BXA Heater
Goodman gms80903bna light blinks once fan runs all the time,
I believe this code is ignition failure.
Turn power off and after 20 seconds turn power on with thermostat calling for heat. Vent blower should come on first. After a bit igniter should lite up. You should hear click noise of gas valve open up. If igniter does lite and you hear click noise, flame should come on for a few seconds minimum. If igniter doesn't lite and you hear click noise from gas valve, igniter is bad. If flame lites and then goes out, flame sensor probably needs cleaned. Both igniter and flame sensor are in metal plate under burners. Igniter has 2 wire going to it and flame sensor has one wire. If you think it is flame sensor you can remove with taking it out with 1 1/4" hex screw. Flame sensor will have white film on it if it needs cleaned, clean with steel wool or a dollar bill. If it isn't weither of these it is gas valve or circuit board.
Jan 27, 2011 | Goodman Heating & Cooling
When i start furnace fan starts comlete purging cycle but not igniting indicator light blinks rapidly
though your draft induced blower goes through its cycle, your pressure switch may not be proofing to open the main gas valve.
Nov 28, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
My goodman heater will not run all of the sensors check out ok and have voltage the vacuum switch is also working I am getting one blink after the furnace shuts back down,there is no voltage to the...
This is a step system for heat ,,, step 1....... thermostat calls fo heat and send power to the vent fan motor, it proves its running by a small suction on the red tube which closes a switch and tell the c. b. to go to step--2 lite the hsi this glows &in20 seconds....step --3 the gas valve opens and dump raw gas in the venturis tubes.. and proves it has a flame thru the flame sensor. and step 4... the box heats up and closes the fan switch..
Dec 20, 2009 | Goodman Heating & Cooling
Goodman 075-3 fan runs but no voltage going to igniter
One thing you can checkmis the continuity through the ignitor itself if you have continutity through that there is also some safeties it has to go through but the board is where the voltage is supplied for the ignitor. I would check the high limit and the roll out before condeming the board.
Dec 20, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman gas heater 075-3 will not start,the unit comes on but there is no voltage to the igniter,the OBD shows one blink
once the draft motor starts the proof switch will make (a small rubber tube runs from motor housing to switch) it sould make to let the igniter intergize. check tubing for holes or kinks
Goodman GMP075-3 ignition problem
bad board,i have had several board failures on goodman
Dec 18, 2008 | Goodman GDS80904BNA Open Flame Heater
Goodman ac/gas furnace unit mdl. # gmp075-4
Nov 27, 2007 | Cozy (W352E) Heater
Goodman GMS90703BXA Heater Logo
350 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
