Question about Konica Minolta Maxxum 3Xi 35mm SLR Camera
My Minolta Maxxum 3xi won't take a picture!
I just recieved a Minolta Maxxum 3xi for my birthday from my grandma, I loaded the film correctly placed a battery in it and everything.
When I go to take a picture a red lightning bolt slowly flashes and when i press the button to take a picture a yellow triangle pointing downward flashes once, but really fast. And I can't take any pictures, please help!
  • Anonymous Feb 23, 2009
    same here
  • Eric Pohl May 11, 2010
    Look in the lens opening when it's mounted on the camera. Are there several blades visible with a small opening in the center of them?
poolseman
  • 206 Answers
SOURCE: where to get a Repair Service for my Minolta Maxxum 3xi?
Lens fully closed so viewfinder is dark and secondly your auto focus will not work either in this condition ( not enough light reaching the sensor at the bottom of the mirror box ). Problem is the aperture control mechanism called 'the base plate set' situated next to the mirror box in the body , which is faulty. This can be repaired but requires removing of the mirror box so that you can access the small drive which has a faulty gear and which drives the aperture mechanism. I charge +- $150 to repair this common problem.
Posted on Sep 16, 2007
informatica
  • 1114 Answers
SOURCE: rewinding
Hi - You can download the manual from the link underlined in blue below:
Maxxum 3xi part 1
Maxxum 3xi part 2
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 18, 2008
SOURCE: Minolta MAXXUM 3xi the view finder is very dark(bought second hand)
I no the older Minolta's had an aperture problem the pictures when zooming out after they were developed were very dark. But inside and wide angel shots always came out nice I had to have the aperture base plate replaced on my Minolta Maxxum 3000i my point and shooter, I wish this helped but it sounds like something different in your case it also maybe the aperture acting different in your camera than it did in 1 of mines.
Posted on Feb 04, 2009
pontelemon
  • 538 Answers
SOURCE: Auto rewind on my Minolta camera
Broken gears in Advance Assembly.
Needs service.
Posted on Apr 02, 2009
Obertelli
  • 3006 Answers
SOURCE: what size lens fits a
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Posted on Sep 03, 2010
How can i change the ISO on my camera (minolta maxxum 3xi)? The film i put in is 400 but the assignment requires me to change it to 100
Okay. Just bear in mind that the exposure meter is going to be two stops off, unless you're getting the film pull-processed.
The Maxxum 3Xi unfortunately does not have a way of overriding the Camera Automatic Sensing portion of the DX encoding standard. That is, if the film cartridge has the DX encoding, the camera will set itself to the indicated speed.
However, if the film cartridge is NOT encoded, the camera will set itself to ISO 100. So, if you tape over the magnetic encoding on the cartridge...
The CAS is not the barcode on the film cartridge, but the rectangular patches of conductive and nonconductive material.
Take a look at http://en.wikipedia.org/wiki/DX_encoding for more information about the DX encoding.
Jan 13, 2011 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Does the film load and picture number stay on constantly even when off.
Yes. LCDs consume so little power that there's little point in blanking it out (think about digital watches).
Dec 21, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Changing ASA on minolta Maxxum 3xi
Not a feature of that model. It reads ASA from the film canister. You cannot manually set it on the 3xi.
lightspiritphotography.com
Oct 29, 2009 | Photography
When film is developed pictures are half solid black
If you are using a flash, than you shutter speed is too high for the shutter to fully open. if you are in daylight than your shutter is malfunctioning and needs repair
Sep 18, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Needs service.
Mar 22, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Rewind runs but film still seems stuck & won't rewind-Max 3xi
It could be that there is a broken or missing gear in the rewind. It will spin but not catch. Sometimes when film is loaded it, is not drawing the film across and missing a gear, so it seems like your taking photos and its not. If you sent it to minolta, good luck, they were bought out by Konica, and probably didnt' do a thorough analysis of it.
I have a friend who fixes cameras. Cleans them, lubricates them, and callibrates them,
http://www.cameradr.com/
Hope this helps you
Nate
Dec 30, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Nov 24, 2008 | Konica Minolta Maxxum QTsi with 35-80 lens...
Rewinding
Maxxum 3xi part 1
Maxxum 3xi part 2
Informatica
Aug 17, 2008 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Manual
Maxxum 3xi part 1
Maxxum 3xi part 2
Informatica
Konica Minolta Maxxum 3Xi 35mm SLR Camera Logo
75 people viewed this question
Top Konica Minolta Photography Experts
Greg Cann
Greg Cann
arjoy ceniza
arjoy ceniza
Are you a Konica Minolta Photography Expert? Answer questions, earn points and help others
