Question about Sharp Televison & Video
How can i use my tv as a monitor i have connected laptop to ex 4 but no luck
  • 979 Answers
Many Sharp units lack the format capability to display computer video as it Is different from NTSC, PAL and SEcam.
Posted on Nov 20, 2008
How to connect 4 x HPL1706 monitors to a TV or PC/Laptop?
Did you try using a "Y" adapter cable. That would allow you to connect to two devices.
Mar 25, 2015 | HP L1706 17" LCD Monitor
Onkyo tx-nr616
harder to do but you can probably still use the display on the unit.
I am unfamiliar with the onkyos but am often setting up integras which are basically onkyos.
Find the setup button on the face of the receiver. It might be called different things but basically you will call up the settings and use the arrows - enter - and return to navigate in and out of the menu options.
Integras have that will allow you to;
configure connected speakers
- sub yes-no
- center yes - no
- rear surround yes-no
- speaker size small-large
input config (mapping audio, video connections to the input names)
ex:
- "Cbl/Sat" -> HDMI 1 - 4
- "BD/DVD" -> HDMI 1 - 4
etc.
You'll get the hang of it.
OR - do you have a small TV with a composite video connection?
I carry around a portable Coby battery powered monitor that has a composite video input for these types of problems. Composite video is always active.
May 26, 2014 | Onkyo TX-NR616
2nd monitor problem
Did you switch the TV to PC? With the channel selecter.
Jan 15, 2014 | Dell Computers & Internet
I have the connection for my laptop to tv what do I do after I connect the two
On your laptop keyboard it should be a key to switch to external monitor. You may need to press the FN key plus a key to switch to external monitor.
If you are still having problems, try to include the make, model# of laptop and the cable or device you're using to connect the laptop to the TV.
Best of luck to you.
www.aaatvservice.com
Nov 03, 2013 | Televison & Video
My screen went blank??
Have you tried to connect a VGA cable from your laptop to a different monitor?
That would prove weather or not it was the monitor at fault or the graphics card.
Most TFT TV screens have a VGA connection, you would just need to find a D-Sub - D-Sub VGA cable to test with, if it wourks on the TV your monitor is faulty, if not your laptop GFX card will be faulty, either way you will need to claim on the warranty.
Good luck
Apr 22, 2012 | Samsung P30 Notebook
Cannont connect my laptop to my home theater system (NS-H2002-U) using my HDMI cable. Why cant i get the screen from my laptop to appear on my TV through my home theater system
check your laptop their is a sign of two monitors on it, click the FN plus the function keys of the keyboard. ex: fn+F4.
or try use VGA Cable instead of HDMI cord, from your laptop to your LCD TV.
Hope it helps thanks.
Sep 10, 2011 | Computers & Internet
How to connect Acer 55610-4491 with Sony Braveria Ex 400 TV?
the connection is possible only if the Tv has a VGA plug ...or if you want to use a hdmi cable ..make sure that the laptop has a hdmi exit..
For hdmi the connection is made directly in the hdmi 1 port ..choose the port into the tv ..and after that open the display properties..or the setting in the video driver ..and enable ..the clone display for moth monitors... This way you will have same image on both .. The sound has to be enabled separately ..from the sound manager in control panel..(enable digital sound)
If you use the parallel port vga..on th eside...than it will work right the way ..or you will have to press Fn+F4 key to enable the second monitor option ..(this can be also enabled from the video driver settings..
In this case he sound will be on the old way on the computer 's speakers..
Dec 25, 2010 | Acer Computers & Internet
Connecting laptop to hd tv
IMake sure that you have the laptop for an VGA OUTPUT. When you toggle between the function keys. When your laptop LCD goes out it is in VGA OUT mode....when you toggle again it should be in LCD/VGA OUT (both TV and laptop should display). You need to set the TV to VGA mode as well...otherwise you might not get an output. If you still have a problem then test on a regular monitor to see if you are getting an output to the monitor
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Acer Aspire 1640Z Notebook
I can't play movies on my tv
Okay, this monitor setup is a little strange. There is an "AVC" component with this monitor that you use to connect everything. There is a 4 cable string (power, s-video, DVI, display port) that connects the AVC unit to the monitor. You must have all external equipment connected to the AVC unit, not to the TV itself. The connections on the TV talk to the AVC unit. I will assume you will be connecting the Blu-ray player via HDMI. HDMI is on input 4 on the back of the AVC unit. hit the input button on the remote or the TV and select input 4. There is a way of customizing the inputs to read out what you have connected to them (ex. DVD, VHS, etc.) to make it easier to use. This should get you signal from your blu-ray
Nov 06, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How do i set my acer travel mate 2312lm to 1440 by 900 pixel so i can work my lcd tv
**Your Laptop has VGA port for connecting external monitors :
Laptop Video Specs :
Laptop's Max Resolution1024 x 768
Integrated Video card : SiS Mirage M661MX
NOTE : If LCDTV does not have a VGA port, you will not be able to use it a external monitor.
Steps :
1. Connect Laptop to LCDTV using a VGA Cable
2. Right-click on your desktop and select "Properties." (or click on start > Control Panel > Display)
3. A new window displaying several tabs will appear. Select the tab called "Settings."
4. You will see boxes with numbers on the middle, in your case 1 and 2 will be present.
5. Click on 2 and click on box beside "Extend my windows Desktop onto this monitor" then choose the resolution that you like (1440 by 900) then click on apply. If 1440 by 900 is not available, choose the closest under 1440 by 900. Don't go over 1440 by 900 since that is the max value that will work on you LCD TV.
6. After clicking on Apply, the display should be present on the LCD TV. (The disply is an extended desktop so you will not see the start button nor the taskbar on the LCD TV. but it should have the same wallpaper. You can Drag the windows to the LCDTV. This will serve as an extension of you desktop. (Ex : You can watch movie on the LCDTV and you can do documents on the laptop's screen at the same time).
Oct 27, 2008 | Acer Computers & Internet
Televison & Video Logo
23 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
