Question about Black & Decker Blower Vacuum Mulcher 1 Ea
How do I change from vacuume to blower
Having trouble removing vacuume to attach blower. No manual. Have it turned in off posistion. Thanks ____annie______
How do i attach the bag to the vac
what part are you having a problem with?
put large u shaped pip in the bag pull the small end out of the hole in the other end with the u shape on top where the strap is the large end stayes in the bag , remove the blower pipe off the front end and put the u pipe in the front of blower put the rib in the grove turn it till it locks, now get a screwdriver find the latch on the front end of the vacuum cover on the left side of blower, put the screwdriver in latch lean screw driver towards the front and pull up on the cover hold the cover open till you have the large pipe in the hole turn and align the tabs with the slots then you know push it push it in real good then turn it counter clock wise till it clicks then get the pipe with the slant on the end align the slots and groves and then push it push it in real good you did not post what model you have so here is a manual hard to read so luck at the pictures good luck and push it push it real good when you get finished with the yard ! User Manuals
Nov 09, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Challenge GBV180 Garden Blower Vacuum. I can only get it to blow ..does this model vacuum and if so how do the bits attach ?
remove the blower tube by turning anticlockwise. remove cover from air inlet same way. attach large diameter suction tube to air inlet (has to fit correctly as this is where the safety switch is) attach collection bag to air exhaust opening (where you removed the blower tube from)
Oct 15, 2010 | Garden
Leaf blower
brand, model number please
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 10, 2009 | Garden
How do i switch to vacuum...i lost my manual
turn your blower upside down, there should be a slot with a metal thing in it. Stick a Flat head screwdriver in the slot, and push forward or back on the screwdriver, that should open the door on the bottom. Attach your bigger tubes to the bottom of the unit, and the bag on the plower part, and there's your vacuum.
Jul 31, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
Unblocking sinks
Remove the brushead and attach the adapter (round cup-looking device with a screen or grille on the front).Attach the hose to the blower (bag) side of the machine.In your attachment caddy,there should be a round rubber attachment with rubber teeth around the outer edge.Should be called the pet grooming tool.Grap the attachment and flip the teeth edge back as if you are trying to turn it inside out.It's now ready to use.If you are trying to unclog a dual (kitchen) sink,make sure the other side has the stopper firmly in place so that there is a seal for the entire drain system
Dec 14, 2008 | Kirby Ultimate G Bagged Upright Vacuum
B & D leaf hog (blower/vac)
Check an see if a branch or something got caught in the blower an won't let it turn, if it hums that could be the problem
Nov 11, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Craftsman leaf blower/vacuum
There is a round grille on the bottom of the unit. Insert a flat blade screwdriver into the latch to release it and reveal the vacuum opening. You should have a two-piece intake pipe that will attach to the opening.
The collection bag attaches to the smaller outlet where the blower pipe used to be (unscrew the wing nut to release the blower pipe). The bag clips onto the hooks at the base of the opening.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
The leaf hog BV4000
Put the switch in the center off position. That allows you to press the big black button in the front and take the vacuum attachment off. Replace the vacuum with the blower attachment and you should them be able to blow rather than vacuum.
Oct 25, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Don't have a manual for my kirby - trying to turn on the blower to unclog a drain but can't figure out how
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566440
Generic problem for all Vacuums
Posted by ssinghnyc on May 03, 2008
Don’t have a manual for my Kirby - trying to turn on the blower to unclog a drain but can't figure out how.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get a Kirby owner’s manual is to call the Kirby Factory and they should have older copies or @ least they can photocopy an older owner’s manual for you @ the address that I will provide for you. I believe that there is a special cuff with a hose attached in order to do the unclog of the drain. I personally have not seen this done but I know the exhaust / blower port on the Kirby serves as a blower. You may look for that hose cuff for that feature. Or , check with your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 03, 2008 | Vacuums
Shampoo system not foaming
Thank you, Mine is doing the same thing, I talked to the Vacuum repair guy in my town and he says the berrings(?) go out alot on the Kirby shampooers. But I will definitly try what you did first before replace the Berrings. Thanks, Annie
Jun 25, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Black & Decker Blower Vacuum Mulcher 1 Ea Logo
148 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
