Question about Microsoft Zune JS8-00001 Digital Media Player
Zune Hold Button broke
I had my Zune on hold and a song i didnt like came up , so i tried to take it off hold and it wouldnt turn off the hold, then when i got home i noticed the hold butten was loose, not falling out loose, but it would just slide acrorss the little part instead of clicking....i can connect it and all but its as if its still on hold, it shows the small lock symbol on the bottom right of the screen...if i cnt fix it, where can i send it to get it fixed?
  • 1 more comment
  • Anonymous Jan 12, 2009
    The same thing has happened with my Zune. I can't seem to figure it out.
  • Anonymous Jan 18, 2009
    i haveeeethee sameeeeeeee
  • Anonymous Jan 27, 2009
    i have the same problem!
  • 38 Answers
Http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Step 1 thru 4. Picture 4 shows where the Hold switch is right below the top arrow on the left hand side. Look see if it is broke. If not, re-assemble vewy vewy kehfewy.
These folks also do repairs.
*** I do NOT recommend or endorse that website! It just looks like they are more on the ball than Msoft.
Posted on Mar 11, 2009
Zune hard drive problem
You have 2 options when your Zune is acting up;
When dealing with MS tech support, you may be advised to reset your player as part of a troubleshooting effort...This is called a soft-reset.
With your Zune turned on, press and hold the back (left) button and the "Up" button on the control pad at the same time. Your player will reset itself.
When a soft-reset doesn't work...
Under rare circumstances you may need to reformat your player. (Typically you wouldn't do this only when directed to by Zune technical support.)
First, press and hold the back (left) button and at the same time press and hold the "up" button on the control pad.
The player will start to reset; as soon as it does, hold down the back button, center button, and right button at the same time.
Your player will then inform you that it is deleting all media on device, and your Zune should revert to the "way it was" when you first pulled it out of the box - except that you will lose the pre-loaded content.
You will lose all the songs and video you've loaded it with...but the software apps it came from the store with will still be there.
Apr 09, 2010 | Microsoft Zune JS8-00001 Digital Media...
Want to put music back on my zune,it wouldn't sinc,
May have to reset the zune to factory default settings...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
Mar 12, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune freezes on black screen
I just had this problem. Try an emergency restart. Hold down the <- arrow button (the button on the left) while pressing the up button on the pad. Hold untill it until the zune symbol comes on screen. Hopefully that will fix it, thats what I did...
Jan 14, 2009 | Microsoft Zune JS8-00001 Digital Media...
When selecting a song the zune got stuck
push and hold down the back button and up on the "D" pad at the same time it will shut down then you can turn it back on and worky worky
Nov 17, 2008 | Microsoft Zune JS8-00001 Digital Media...
My zune
If it freezes up hold the pause button and turn it off, then hold down the back button and up on the keypad and it will restart. If for some reason it keeps freezing constantly I suggest you contact zune.
Oct 26, 2008 | Microsoft Zune JS8-00001 Digital Media...
All my song in my Zune not play at all
unlock zune. click the back button like ur going to menu. and hold it. then on the circle thing hold the up button like u want to go up songs hold both and zune restarts. and ur good.
Jun 06, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune problem
Download and install the latest zune software from microsoft. Run the new zune software, plug your zune into the computer and it should prompt you to install the latest firmware automatically. This is all that is necessary with the majority of firmware problems.
May 12, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune will not sync
Okay... what you do is Hold your zune in you right hand.. open the toilet bowl with your left.. put the zune in the toilet... and then flush it... or if you have not gotten a zune... just throw the $200+ in the toilet instead.. Because i have the same exact problem as these guys and none of their solutions have worked..
Feb 04, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Mirosoft zune froze up
To restart the Zune device, follow these steps: 1. Set the Hold switch to the unlocked position. Note To make sure that the Hold switch is in the unlocked position, you may have to move the switch back and forth until the switch is in the correct position. 2. Press and hold the Back button zune_button_back.gif while you press the top of the Zune pad
Dec 26, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Microsoft Zune JS8-00001 Digital Media Player Logo
1,738 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
