Question about HP Color LaserJet 2600n Printer
Print Spooler not running
I have gone into services and tried to start the spooler. Error 1068 comes up. Is there anything else I can try?
  • 1 more comment
  • glauth Nov 21, 2008
    Thank you. I tried that. The result is the same."Could not start print spooler service on local computer. Error 1068: The dependency service or group failed to start.
    Under dependencies there is a LexBce Server with the RPC attached to it.
    It is now working. Thank you.
  • HP Master
  • 4,338 Answers
Follow these steps to correct the issue:
Go to Start > Run and type in services.msc then press Enter.
2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately. You're all set! Now when ever your Print Spooler craps out, it will automatically reset itself.
Let me know if this helped,
If it did please rate it, if not I'll research it some more
Posted on Nov 20, 2008
  • JDTec
    JDTec Nov 20, 2008
    Also try this:
    Go into services and check its dependencies, it should just be the RPC service, which you shouldn't be able to stop, check that RPC is running
    Double click print spooler and click the dependencies tab. See if there are any other dependencies set besides rpc. If so you will want to find them in services and make sure they are set to automatic and are running (will probably need to start them).
    Then try to start "Print Spooler" service, should work. May need to reinstall printer drivers then.
I have installed hp photosmart and get an error message '' restart print spooler error 1068'' I have tried everything but cannot restart my printer spooler.
go back to your services where you start the print spooler. open the dependency tab. there it will tell you what other services the print spooler needs to have running. check them and if any are disabled change them to auto and restart them. reboot and you should be OK.
Nov 05, 2009 | HP Photosmart 7450 InkJet Printer
Hi i have aprob my computer say the printer spooler cannot running error 1068
Check for other Service Dependencies A 1068 is a service dependency error. Print Spooler can't start because it thinks a service it depends on is not running.
shortcut: start-run-"services.msc"
Apr 21, 2009 | Computers & Internet
"Error 1068 Could not start the Printer Spooler on local Computer"
I appreciate the opportunity to help you. Try the following:
Check dependency services on Print Spooler
1.Click "Start", input "services.msc" (without quotation marks) to Start Search bar and press "Enter".
2.Double click the “Print Spooler” service.
3.Choose “Dependencies” Tab and remember the services name.
4.In the service list window, find the dependency services and try to start them.
5.Please try to start the “Print Spooler” service again.
See if this helps. If it does, please fill in the rating of my service to you. Thanks for using Fixya.com
Jan 27, 2009 | Office Equipment & Supplies
Spooler not running after Lexmark x83 installation on windows XP laptop
From what you're saying the windows print spooler service is not starting following the installation of your printer (and thereby you cannot print i'm assuming)
try the following to start the print spooler service if it is not already running.
Click Start
Right Click My Computer
Click Manage
Click "Services and Applications"
Click Services
Scroll down to "Print Spooler" and double click on it to open up the properties page
where it says "startup type" select automatic from the combo box list
Apply
If the service is NOT running, start it by clicking "start"
click OK
The print spooler service is started now, and **should** work properly. If the spooler is still not starting properly, then you may have a driver issue and i reccommend uninstalling and reinstalling the drivers for your printer.
Jul 01, 2008 | Lexmark X4270 All-In-One InkJet Printer
HP print spooler problem and error 1068. Want my printer back!!!
hi! Print Spooler is actually a service for your Operating system-
Try this
Click on start and click on run
in the open box type in services.msc and your services local window should open, scroll down and look for print spooler, highlight it and do a right click and on the dropdown menu left click on stop and it will go to a process of stopping the service and then right click back and click on start. if you get an error message about print spooling or spooler, then that means you have a problem with the operating system. call or go to microsoft help and support online in that case. and RPC server unavailable error has something to do with a network printer. but i believe you setup the printer locally.
You can email me at dabesderis06@gmail.com
Apr 04, 2008 | Epson CX8400 All-In-One InkJet Printer
ahah..first things first...what Windows Operating system do you have...??
Feb 10, 2008 | Lexmark X1270 All-In-One InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Print spool error 1068
click Start, then click run. Type in "services.msc" without the " " marks
Oct 19, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
HP Color LaserJet 2600n Printer Logo
236 people viewed this question
Ben Johnson
