Question about RCA P52926 52" Rear Projection Television
My RCA p52927 tv will not turn on
When I push the power button nothing happens. The chasiss number is PTK195M2B. Before it totally went out I had the hour glass effect from time to time. What can I do?
  • macedogalo Nov 27, 2008
    When I push the power button nothing happens and when I turn on by my finger appear on screen the code P0 1.5 V0
SOURCE: 52 RCA DLP 1080P Television with NO picture and buttons flash
i dont have a soultion for you but can tell of my experince with rca 52"dlp after having mine for six months did same thing sent it to the repair shop it stayed there for three months then they said they couldnt fix it tried to talk to rca cust serv reps who basicly said they didnt care after two more months i finaly got the store manager where i bought it to go to bat for me and they agreed to replace it but with a lower grade model and no warrenty as they said mine had expired even though it had been broken for eight months after three months the new one did the same thing i was told it was the light engine which cost 2 grand and were on forever backorder and id just get another tv before putting that much in that tv but it wont be another rca hope this helps now i have a 100lbs paper weight b4829@yahoo.com
Posted on Dec 28, 2007
Slinteriors
  • 8617 Answers
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
xMadx
  • 64 Answers
SOURCE: my rca d52w20 52inch tv doesn't want to turn on
Well not knowing this particular unit myself, i would strongly suggest troubleshooting the users manual, which can be downloaded here.
http://tv.rca.com/en-US/UGConfirm.html?modelno=D52W20
Posted on Jan 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
Posted on May 06, 2008
  • 927 Answers
SOURCE: RCA P52927 volumn control
The buttons on control panel are there for convince not for everyday use. Use remote, your control panel is bad.
Posted on Jun 01, 2008
Sharp LC40LE600E wont turn on
Had exact same symptoms as Keran. Turned out to be my daughter had turned the TV off with the other power switch which is a button on the right hand side of the set - we always use the rocker switch on the left hand side and had forgotten about the button. Turned the rocker switch on, then the button and it was back to normal.
Jul 19, 2012 | Sharp Televison & Video
RCA 27v520t will not turn on
That's because somehow the lightening caused a fault in the power board.
Ypu can try an unplug for 2 hrs and then reconnect and start again If that dosn't work you will require intevention to replace the power supply
Aug 17, 2009 | RCA 35V432T 35" TV
Tv will not turn on
I turn on tv green light comes on and gos off and no picture.
Feb 04, 2009 | RCA D52W19 52" Rear Projection Television
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 24, 2017 | Televison & Video
RCA Scenium HD52W140 Won't power
This has happened to me twice. We had the warranty and thank God we did. The problem is in a $7 transistor and you probably need to call a repair shop. They worked on ours and it took about 20 minutes to replace the transistor. They take out the bad one and soder in the new one on the circut board inside the back of the tv. The total cost was nothing for us because of the warranty, but it came to $385 for labor and stuff. Again, this happened twice, one year to the date from one another. The repair guy finally installed a different brand of transistors and it's been fine since. He said that RCA makes some terrible transistors and he will not use them again. Try and get the repair person to use a non-rca brand transistor, because it will more than likely happen again if he don't.
Dec 28, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nov 11, 2007 | RCA P52926 52" Rear Projection Television
On off on my 32 inch rca
Bad tactil switch behind buttons or possible bad solder connects
in microprcessor circuit............Sounds like an odd problem....T.
Nov 07, 2007 | RCA F32450 32" TV
Tv not powering on
as per your statement there is a loose contact in power supply section of your tv. it is 1oo% sure that allthe parts are ok as tv runs ok when it comes on. but you will have to call tech. as without knowing technology it is dangerous to open tv due to high voltage.
Sep 15, 2007 | RCA HD52W58 52" TV
RCA P52926 52" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
