Question about Dryers
MY WHIRLPOOL FRONT LOAD DRYER TAKES 1.5 TO 2 HOURS TO DRY A LOAD OF TOWELS OR JEANS.
    Genius:
  • 1,028 Answers
Ck vent all the way to outside to verify vent problem try a load with vent disconnected may get a little warm and dusty but will prove vent issue
Posted on Nov 21, 2008
My electric dryer takes a long time--3 hours or more to dry a load of wet towels
The heating element may have failed. Also, the vent may be clogged.
Aug 15, 2016 | Kenmore Elite HE4 Electric Dryer
My whirlpool dryer will not dry clothes in one try.takes a second time to dry a load. especially jeans or towels
Make sure the lint filter is free of dirt. If this is a gas dryer, listen for the burner switch on. If you hear it switch on and switches off in less than a minute, you will need a new gas valve solenoid. This part goes part and goes on safety - switch off gas. In return you only get a air dry (not heated).
Mar 01, 2011 | Whirlpool Dryers
My whirlpool duet dryer doesn't get jeans or towels dry
jeans and towels are very thick, they will take more time to dry.
Apr 07, 2010 | Dryers
Whirpool dryer takes 3 hours to dry jeans or towels.
Most likely your heating element has partially failed. Some dryers have two separate resistance heaters in them. If one fails what you are describing can happen. If you have the tools and are willing to take it in it's not that bad a job. You have to take the cover off the dryer to see it, then it is two bolts. Any appliance repairman can handle this easily.
Mar 22, 2010 | Whirlpool LER5636P Electric Dryer
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Not heating and drying clothes properly takes about 2hrs to dry jeans??? what is the problem
frist check the vent if this is to difficult for u pull vent hose from dryer run dryer with load 45min normal dry time . longer for jeans 60- 70 mins. if this works. u have vent problem. if not remove back of dryer replace cyle tstat this is one closer to vent duct problely 4 wires
Oct 26, 2009 | Whirlpool LER5636P Electric Dryer
Takes 4 hours to dry a load of towels. plenty of heat - just not drying
How damp are the towels? More moisture= more time to dry
Is the dryer full to the top with towels? There needs to be enough space to allow for air flow in and out.
Also check exhaust vent to make sure it is not blocked.
Oct 09, 2009 | Whirlpool GEW9250 Electric Dryer
Have heat & tumbling but will take 3 hrs to dry a load/ no jeans
Likely that your Dryer vent is clogged up. Especially if its long. Check that by hooking up a shopvac to one end with duct tape to seal any air leaks between the vent pipe and the vac hose. Turn it on and check the other end of the vent pipe for suction. If its faint then there may be a crapload of lint in there or a birds nest. Compressed air in the pipe with an agitating device may work or shopvac hose if run is short. Be prepared for a mess on either end.
Heather
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
My Whirlpool Clean Touch electric dryer is not drying clothes very well. It is not getting real hot, and it takes two cycles to get most things dry. Towels and jeans take part of a third to dry. I clean...
IF YOUR DRYER HEATS AT ALL, BUT WON'T DRY THE CLOTHES, 99 PERCENT OF THE TIME THERE IS A RESTRICTION IN THE AIR FLOW. PULL THE EXHAUST OFF OF THE BACK OF THE DRYER AND DRY ONE LOAD. IF IT DRIES O.K., THERE IS A RESTRICTION IN THE DUCT WORK.
CLEAN OUT THE LINT FROM THE DUCT WORK. IF THE DUCT WORK IS FLEXIBLE MATERIAL, REPLACE IT WITH RIGID 4 INCH METAL DUCT.
Apr 16, 2008 | Dryers
Dryers Logo
75 people viewed this question
Top Dryers Experts
Marvin
Marvin
