Question about Cardinal Airlife Brand Modudose 5 Ml Unit Saline Solution for Inhalation 100/box
There is no mist coming out of the neb machine.
The amchine is turning on and it is vibrating but there is no mist coming out of the mask. How do I fix this or do I just need another machine?
  • Anonymous Jan 24, 2009
    I have the same problem, There is no mist coming out of the mouth piece.
    Problem Solver:
  • 5 Answers
No! don't buy a new machine. First wash the mask, tubes and any other washable part really well by hand. There could be some dryed on fluid blocking the flow of the liquid. Then make sure that the part where you put the liquid does not have liquid on top of the ******** part. Usually a bit of shaking off of the liquid or using a paper towel to dry that part off should help. If this doesn't work let the nebulizer dry out overnight with all parts seperate. I constantly have these kinds of problems with my nebulizer and these seem to do the trick if these don't work then you might need a new machine.
Posted on Nov 28, 2008
I have a Cool Mist Homedics Ultrasonic humidifier, Model UHE-OC1A that has stopped working...I have cleaned it, the small lights go on when turned on, but no mist is coming out ... ???
In the bottom of the humidifier is a little disk that vibrates to turn water to vapor. This gets covered in mineral deposits and won't vibrate properly. They usually suggest something like vinegar to clean it. I found that this didn't work for me. What did work was cleaning it with my Waterpic on the highest setting. It chipped away the deposits and allowed it to work. HOWEVER, once you get it running again, buy the slant fin mineral absorption pads to keep it running. If you have mineral-rich water like me, you'll go through them quickly, but you also won't have white deposits on your walls anymore.
Feb 24, 2015 | Homedics Cool Mist Humidfier - Uhe-oc1 -
No meds coming out of the mask on the nebulizer
Make sure that the line is cleared and going from the little are you put it into to the full mask into the mouth. Also, make sure you use cold water to clean the unit and never use soap to clean it, that will breakdown the chemicals for the Neb machine. Take care...
Sep 10, 2010 | Medline Industries Health & Beauty
No medicine coming out of nebulizer
Replacement of neb kit the most common cause. Try this first. Then get back with me.
May 31, 2010 | Respironics HS800 Disposable Nebulizer Kit...
What face mask would fit on the Evo Sport Neb nebulizer
any "generic" nebulizer face mask will fit this nebulizer (except the Pari brand). There are different sizes so make sure get the correct size to fit you. Usual sizes are infant (child/pediatric) and adult. Usually ask the pharmacy to order if they don't stock it.
Jul 29, 2009 | RTO Evo SportNeb Express Compressor...
My solution in the nebulizer is not foaming or misting!
you may need to switch out your mask unit, the cup the medication is put into has a very tiny hole for air to circulate through. if that hole has been tampered with, or is partially clogged you will not get a mist. you should change out your mask and tubing regularily for sanitary reasons.
hope you get it running again!
Mar 20, 2009 | DeVilbiss PulmoMate Aerosol...
Hudson nebulizer leaks
If tap water is used, you may have a buildup of lime deposits; allow it to dry and then look for any white deposits.
Using distilled water will avoid this.
Feb 13, 2009 | Hudson Rci T UPDRAFT II NEB MOUTHPIECE...
Probasic riteneb
If it looks like fog coming from the mask it is doing it's job,If not,the filter may need changing.(A little water goes a long way in those machines)
Jan 07, 2009 | Probasics Rite-Neb Mini Compressor...
Cardinal Airlife Brand Modudose 5 Ml Unit Saline Solution for Inhalation 100/box Logo
2,013 people viewed this question
Top Cardinal Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Cardinal Health and Beauty Expert? Answer questions, earn points and help others
