Question about Audiovox D1020 Portable DVD Player
Horrible Static on both headphones and van speakers when playing
We have a D1020 unit and had no problems originally. The first problem started to occur when my girls would move from directly in front of the unit - their headphones would go dead. We went to just broadcasting the sound over the van's speaker system and this was okay for a while but now there is HORRIBLE static. The static remains even when I switch to a different channel. Could you suggest a solution - I would really appreciate it.
  • gburgard Jan 08, 2009
    Thank you petraman7 - I will give this a try.
  • gburgard Jun 17, 2009
    Thank you for your response, I haven't taken it in for repair yet...I am not sure it will be worth the expense of repair.
    Genius:
  • 1,175 Answers
Hi...
The most probable cause it broken solder connections on the headphone/ext speaker jacks.
If you know someone who can solder fine detail parts...have them try.
I dont know what a TV shop would charge but it DOES need fixing
Posted on Jan 08, 2009
2006 buick terazza speaker problems
Most likely a bad unit. Take it to a GM dealer for a more precise diagnosis.
Apr 06, 2014 | 2006 Buick Terraza
Audio static
That's pretty normal with built in connectors. For a workaround grab a cheap USB sound card from eBay or somewhere else. It worked for me.
High Quality External USB 2 0 3D Virtual 7 1 Channel Audio Sound Card...
Apr 08, 2017 | Lenovo IdeaPad Yoga 11S Touch - 59370514 -...
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
My Toyota DVD system will not transmit sound through wireless headphones or headphones with wires plugged in directly. The sound does play through the van speakers.
I think you will need to disable the Van speaker connection to the DVD system. Can you tell me what is the model of your DVD system. You can test your wired headphones on other devices to see if it works. Then you can check the menu options and see if there is settings about which speakers to use.
Jun 27, 2011 | GPS
Static in the left ear, feels like a bad connection
Hi.
First test if the problem occurs using different output devices. Also ensure there is no earthing problem with the wall socket. In that case you will get the problem even when playing from speakers.
If the problem depends on the speakers, then it is a bad connection. The headphones are not supposed to be disassembled and must be replaced.
Call Bose to sort out the problem.
Bose Worldwide - Contacts
Mar 20, 2011 | Bose QuietComfort® 15 Acoustic Noise...
My hp ipaq 2795 has recently started having static when playing mp3 files with media player using both headphones and the internal speaker while play files that were previously static free . the unit also...
It is, most probably, behaving like that because some application is taking too much processing power, hence, consuming battery, which, by its turn, heats up. Besides, active data connections are known to drain the battery very fast. Anyway, Google for Dotfred's TaskMgr.exe, copy it to your device and run it You'll see which application is taking more power than others.
Just my 2 cents... Carlos
Apr 14, 2010 | HP iPAQ HX2795 Pocket PC
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
Audiovox D1020 will not power on?
I have a unit with a broken screen that I am trying to find a replacement for. (one with a good screen) Please email me and let me know if you are willing to sell yours. Thanks
buckeyevcr@aol.com
Feb 26, 2009 | Audiovox D1020 Portable DVD Player
Honda Odyssey DVD player sound without the headphones
You can set the sound to play through the car's speakers. If you don't want it too loud in front, you can use the audio setting for the fader to just play in the rear.
Jan 15, 2009 | 2004 Honda Odyssey
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Audiovox D1020 Portable DVD Player Logo
127 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
