Question about Epson Stylus Photo 1290 InkJet Printer
Ink cartridges come off carriage
Hey prob with my epsom 1290 a3 printer. I was trying to free a complete jam of paper and nothing was moving so I had to push the ink cartridge carriage out of the way.Now it appears to have lost its tracking on one side and isnt clipped down like the other side is.... Is it completely beyond hope??? Help, please! Constant red light on front....
  • 353 Answers
I'm not too familiar with the 12xx family of printers, but sounds to me like you have broken the print head track arm. Look carefully at the side that has come off the track. The traditional Epson print head design is to have the top track arm as part of the print head, and the bottom track arm as part of the print head carrier. The print head and carrier clip together thus providing a closed arm over the track rail. The key question is, have you merely unclipped the print head and carrier? If so all you need to do is position the upper and lower jaws over the track and push the print head and carrier parts together until they click. Alternatively, is a lower or upper jaw missing? In which case, one or other is broken - disaster I'm afraid.
Remember, I'm talking about generic Epson design of the 1290 vintage. I have the 1290 service manual, which is of the usual Epson rubbishy standard, but it's not the same as having actually dismantled one, which I haven't. However, if you look carefully at the side of the print head that's come off the track rail, you should be able to spot if anything is missing i.e. broken off.
Posted on Feb 01, 2009
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
Cartridge Carrier is Blocked
Check the all-in-one product for paper jams and reset the paper feed motors.
Normally the cause of these errors is a piece of paper or other material in the paper path. Sometimes the paper feed assembly has become unsynchronized. Use the following steps to correct these issues:
1: With the all-in-one turned on and ready, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move.
2: Unplug the black power cord from the back of the product. The power plug must be pulled out to resynchronize the paper feed and carriage motors. Simply turning the product off does not work.
3. Remove both ink cartridges and lower the ink cartridge latches, as shown in the figure below, so that they do not catch on the product frame when the product reinitializes. Do not close the ink-cartridge access door at this time.
4: Remove the remaining print media from the paper supply tray. Discard any pieces of media that are damaged.
5. Unlock and remove the rear access door.
6. Being very careful, slowly and gently pull any jammed media out of the product through the rear access door.
7: Make sure that no jammed media remains in the product. Be sure to check inside of the product on the sides to verify that media did crumple into these areas.
8: Reinsert and lock the rear access door. Make sure that the door locks fully. The paper can skew if the rear access door is not fully locked.
9. Close the ink-cartridge access door. 10. Plug the power cord into the back of the product. If the product does not automatically turn on, press ON. Let the product initialize until a front panel message appears, requesting ink cartridges. If the carriage cannot move, remove the power cable again and determine what the carriage is caught on. Manually move the carriage to free it from whatever has blocked, it and then repeat this step. 11: Open the product and reinsert the ink cartridges. 12. Reload the input tray with print media and try printing again. The media must be loaded properly for it to feed correctly. It must be fully inserted into the product but not to the point that it bows from the pressure. 13. The HP all-in-one product will request that an alignment be performed after closing the ink-cartridge access door. Perform the alignment. The HP all-in-one product should be fully functional when the alignment is complete. It might be necessary to repeat the process more than once if the product was completely out of synchronization. Clean the paper rollers If the issue persists after checking the paper path and resetting the all-in-one product, follow these steps: 1. With the product on, open the ink-cartridge access door. The ink cartridges come to an access point if the carriage can move. 2. Unplug the black power cord from the back of the product. With the power cord unplugged, the print carriage (the part that the ink cartridges are in) can be moved. 3. Locate the four small, metal paper rollers (not the rubber rollers) and the carriage rod as shown in the figure below. The carriage rod is the large metal rod that the print carriage rides on. If these rods are not bright and shiny or if they have buildup on them, they should be cleaned. 4. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the rollers and the carriage rod. With the power cord unplugged, print carriage should move back and forth freely so that all parts can be cleaned 5. Open the rear access door. Use a soft, lint-free cloth lightly moistened with water (distilled water preferred) to clean the three rollers that are shown in the figure below. Close the rear access door when the cleaning is finished. 6. Close the all-in-one product and reconnect the power cord. Try printing again to see if the issue is corrected Hope this should fix the problem Good luck.............
Aug 02, 2010 | HP OfficeJet Pro 1170c InkJet Printer
Error on printer, ink lights flashing, replaced cart. printer was working fine, nothing was changed.
If you haven't already, completely unplug the printer and let it set for a little while. Failing that, use the factory defaults option on its onboard menu if it has one. Make sure there's no paper jam, and, at your own risk, you could open the printer and try to move the printing carriage (the ink cartridges ride on this in most printers) just a little to see if it was maybe jammed.
Feb 21, 2010 | HP Deskjet F4180 All-in-One InkJet Printer
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Carrier jam on printer
There could be 4 possibilities.
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
Correct position of Encoder strip
Hope it should fix the issue.
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
Epson R320 carriage jammed
The ink cartridge is probably not inserted correctly.  Unplug the printer and manually move the carriage to a location where you can take the ink cartridge out.
Remove it and reinsert it, making sure that it is fully located, before applying the power.
Make sure that there is nothing blocking the carriage movement, such as some remnant of paper.
Oct 21, 2008 | Epson Stylus Photo R220 InkJet Printer
My printer will not load and the window says the carriage is jammed. It is an HP Officejet 7410 All-in- one. It first had the message Paper jam and after I opened it and there was no paper jam I...
1. Check if there are broken parts inside the printer-carriage area
2. Turn the printer on and off
3. Clear any paper jam by opening the rear access door at the back of the printer. If there are no paper jams. Clean the rubber rollers with a lint free cloth that is moist with water
4. Make sure that the carriage can move freely
5. Remove then reinstall the ink cartridges
6. Make sure that the control-panel faceplate is correctly installed
7. Plug the printer directly to the wall outlet
8. Perform a partial reset on the printer.
a. Unplug the power cord from the All in One
b. Press and hold # and 3 while plugging the power cord
c. Do not release the two buttons unless the printer would say reset
9. Try to print
10. If this would not resolve your issue then the printer sensor is already defective.
Aug 06, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
Ink carriage jammed
Well, I'm not too happy that the only response I got was solicitation for the Premium Assistance Plan.
Figuring that the printer had pretty much died, I allowed my husband, Mr. Fix-It, to give it a try. He simply pushed up on the front end of the ink carrier and slid it into the opening. This allowed him to get at the cartridges and push gently down on the new cartridge I'd installed. It had not been seated completely. Works fine now.
I'd be curious to know why I found a huge ink spot under the printer. It has probably been there for quite some time, as I usually just dust around things rather than move them.
Mar 14, 2008 | Epson Stylus C84 InkJet Printer
Epson Stylus Photo 1290 InkJet Printer Logo
90 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
