Power surge resulting in: no picture, sound or anything!
YOU SUGGSTD TO LOOK FOR 2 FUSES INSIDE THE UNIT. I have the back off and dont see any fuses. This is not a projection screen.
I am Still lost!!
  • 3 Answers
Hello sterling home the fuse is located in the lower right hand corner of the main power board that is located just off center of the tv to the right a bit.. then there is another 2 fuses on a board located to the right of that and another fuse on the board all the way on the left side of the tv ..hope this helps ..oh and by the way if you end up having a bad power supply i do have 1 for that model ..
Posted on Nov 25, 2008
Why wont power come back on the unit all the fuses are good
Never use a staple on a power wire.
Remove the staple and check for damage within the sound bar.
Feb 27, 2017 | Denon Audio Players & Recorders
Need to fix Philiphs model 60p8341 ptv915
unplug the tv and remove the back cover,locate fuses and see if there bad.if so and you replaced a bad fuse and the unit works consider yourself lucky and invest in a surge protector if you dont already have one.if no fuses are bad you have a bad board most likley the power supply board.theres a risk of live voltage so be careful.
Aug 27, 2007 | Televison & Video
Any help out there with JVC MX J900 number of fuses in system? Do the speakers have fuses? Can't figure out why no sound.
The most likely cause is the main amp unit. Most of these units use an all in one IC amp that does all the work. If it goes then you get no sound.
The fuses inside the main unit if they have gone would remove all power from the system. Generally they would only go if the main power amp or part of the power supply had shorted. In any case it would generally lead back to the IC power amp. I will post a picture below of what it might look like. There's generally a number on it, you can look that up on line before removing it to find the price of it. The Speakers have no fuses in them.
Oct 14, 2016 | JVC Audio Players & Recorders
Today my power went out for a split second and came back on I turn my TV back on it makes a high pitched whining noise and the screen wont turn on. Cant add picture but model number is MW30G71.
unplug your tv. let it sit for a good bit. 1/2 hour did your power just go out or did you have a power surge then no power. surges cause the grid to go down for a second too and that causes problems too. surge protectors are good for everything. also are you on cable? if so have the cable company check they're filters into the house may be an issue but check the tv after a half hour unplgged and then plug in and turn on normally? sometimes it needs a reset time period before the fuses inside will reset themselves.
Nov 17, 2015 | Televison & Video
Colors are seperated on toshiba 50A61
Go into menu and with original remote call up convergence--either it has a problem(will not adjust) or you may with the remote be able to manually adjust the convergence back: sometimes if a power outage/surge it scrambles the convergence memory.
Aug 28, 2012 | Toshiba Televison & Video
Magnatek series 6300A power center. hooked up 120 power to 1991 21ft komfort trailer something popped now hwt ,heater,and out side lights dont work .on low voltage side fuses # 2 and 3 no voltage and...
Sounds like you have a leak in your metal roof needs to be recoated each year to prevent leaks from getting in to your ceiling electrics. Check for voltage with a voltmeter across your fuses or breakers to show if you are getting any juice to power the circuit then investigate that there has not been any shorting across any circuit boards in the fuse box. Need more info to go further.
Dec 03, 2017 | RVs
I believe my tv was involved in a power surge. red/green blinks
Hello:
U just may of blown fuses on the power supply of the television if you are sure it was a surge. If u can open the unit check all fuses on the power supply for open coniditions. If the future is a good Ideal to use a surge proctector as this will protect your equipment. Make sure power is off and remove AC power to check fuses. Sometimes just removing AC power for a least 2mins will reset the unit.
Jul 02, 2010 | Panasonic PT-50LCX64 50" Rear Projection...
Dead microwave, after power surge
look for a ceramic fuse in a fuse holder. probably 15 amp or 20 amp. if this is blown (and likely is) the micro won't work at all.
Oct 16, 2009 | Microwave Ovens
Kenmore Dryer (Model 110.84834201) won't start after power surge
The dryer has a few fuses. I will give the best website I have found it gives diagrams and part pictures for all appliances. I have ordered from them many times and always got the right part. Go to www.repairclinic.com The fuses on the dryer are very easy to change and you can get the parts in only a day or two.
Jul 26, 2009 | Dryers
Picture and sound gone
your fuses may have blown off.
open the back panel and check all the fuses. There are a bunch of fuses in there, my tv has 5 altogether.
I hope this is the problem.
Feb 24, 2008 | Televison & Video
Televison & Video Logo
217 people viewed this question
Top Televison & Video Experts
