Question about Dell Dimension 3000 PC Desktop
Computer keys only sporatically hit
I can be typing along and look up and there are no words on the screen. Sometimes, if I "strike" the key, it will appear. Delete, back space, space bar all cease to work. I had this happen to me twice before (only once on this computer), and I don't remember how I got it to work. This time, I will write down ! (Backspace doesn't want to work to move the exclamation point after "down"). Can anyone please help me? I think its something simple?????
  • Dell Master
  • 5,568 Answers
First, I suggest you unplug and plug the computer connector several times to 'wipe' the pins.   If that made no difference, I would borrow a keyboard to try on your system (or buy one; they're cheap).
The electronics that receive input from the keyboard haven't changed for almost three decades but it was contained in a single-purpose chip that has long-since been integrated into a single IC that handles such 'legacy' tasks. Just as it occasionally happened years ago, the simple circuit can fail whether or not it is in one chip along with other functions.
You might try going to the Control Panel and open the Keyboard section and use the space provided for checking the repeat rate to see if the problem is noticeable there too but all it offers is setings for delay before starting to repeat and the repeat speed.
Posted on Nov 20, 2008
Cutting of bottom of letters
Really, you have a typewriter?
You stop typing before you reach the end. If it is the electronic type with a display, you need to set the paper size to the size of paper you are using.
If you are using a computer and word processing program, again, set the paper size.
Oct 01, 2015 | Office Equipment & Supplies
Hammer wont strike, just bought new.
Check to see if you are in the display mode (it displays what you are typing, the carriage moves along, but only prints when you hit the return key)
Sep 09, 2013 | Brother Ml100 Standard Electronic...
How can one type with a normal typing keyboard rather than hitting abc for a c?
If your phone only has the numeric pad you can change the setting from "abc" to "T9". T9 is a predictive texting mode, so if you wanted to type the word "hello" you would just press the corresponding numbers 1 time, for example: 4(gHi)-3(dEf)-5 (jkL)-5(jkL)-6(mnO), so you would only hit 4-3-5-5-6, if the word is not the first word displayed you can hit the next key which is usually either * or # depending on your phone. The T9 setting is usually changed by again hitting either the * or # key, or sometimes 0. It is also sometimes selected on the texting menu from within the message.
Learn how to use T9
Sep 06, 2011 | Cell Phones
My AX -430 typewriter was functioning well as i was using it. However as i was typing a new word, the letters are no longer visible on the paper. The part that hits or is it the hammer or arm, can no...
It sound like you have a broken part. If the hammer is not hitting hard enough, the armature theat make the hammer strike the keys is broken. This is a common problem with the ax's
Mar 03, 2011 | Brother EM-430 Typewriter
How do i capture my screeen on a HP Pavilion G61336NR (VU181UA) PC Notebook?
A general tip, for any computer, for capturing static (not video) print screen is this:
Hit print screen key (Print SCRN, sometimes needed to use a Fn key combination, depending on the computer's brand) - start any program you'd like to import the print screen to (Microsoft Word or any image editor you like) - paste the screen in the program. In other words, when you hit the Print SCRN key, you just copy your screen at the memory, so all you have is to paste this screen into any available program. TIP: if you press ALT and PRINT SCRN key together, you get at the copy just the active window.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jan 12, 2011 | HP Computers & Internet
Is there a strike over key
Is there no "insert" key? Normally you tap th einsert key and it toggles between insert and over-write (or strike-over) mode. If there is a numeric keypad tape the "0" key on it provided the numeric pad is disabled. Same thing.
Sep 25, 2017 | Logitech 967233 Keyboard
Sometimes when I type on the keyboard it skips keys that I am striking. I have to strike the key harder to make it register. This only happens sometimes, not all the time.
This is cause by foreign material between the key contacts. Sometimes exercising the key vigorously will fix it, mostimes the keyboard has to be removd and contacts cleaned or keyboard replaced.
Apr 08, 2010 | Compaq Keyboard
My ASUS laptop has suddenly starting typing incorrect characters. I have turned off the sticky keys and toggle keys; I have made sure the NumLk key is off; I have made sure the US settings are one. I can't...
i would suggest re-installing word, or better the whole of MS office. when uninstalling first, if the uninstaller asks: remove all previous user settings, so the new install of office won't take over the faulty settings from the previous install
Mar 09, 2010 | ASUS Computers & Internet
Dell Dimension 3000 PC Desktop Logo
41 people viewed this question
Alun Cox
