Question about Dell Dimension 5150 (DIM515MIN) PC Desktop
Yellow flashing light on dimension 5051
Turned off the computer to day and when i went to turn on tonight the yellowe light is flashing and wont let me turn it on. any sujestion
It was the USB port in the front. one of the pins was touching the outer metal wall of the port, thus shorting the circuit and showing up as a low voltage problem. Freed the bent pin in the broken USB port and put tape over the port so someone does not stick another USB key in to the broken port.
System running fine now.
Posted on Dec 23, 2008
  • Dell Master
  • 998 Answers
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 20, 2008
Dell dimension 5150. wont start
Most times when you have flashing yellow light there is issue ether with cpu or motherboard. Just to be safe test the power supply and if ok then try to replace cpu and go from there. If power supply issue just replace it. Might be easier to take it to pc repair store. Good Luck
Apr 05, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Power button flashes yellow and will not power up.
Try a different know good working power supply and only hook up the main power connector to the motherboard as well as the p4 connector. If you get power then you know that the original power supply is bad.
If you try another known good working power supply and you get the same yellow light then the motherboard is bad and would need to be replaced.
Jun 27, 2009 | Dell Dimension 3000 PC Desktop
Having the yellow flashing light
Sounds like maybe a power surge killed the TV. If it is newer, try contacting the Manufacturer for warranty repairs.
Apr 16, 2009 | Toshiba TDP-ET20U DLP Projector
Computer won't turn on
A flashing yellow power LED is an indication of a failure in the power supply. If under warranty, Dell should be replacing it. If out of warranty, then a 400/450 Watt ATX power supply should resolve the issue.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182021
Apr 06, 2009 | Dell Dimension™ E510 PC Desktop
Start button flashes yellow - will not turn on
I have found that if the CMOS battery is removed and the unit unpluged for 5 mins (reseting the unit to default config) It will restart. The battery should not be replaced thus to maintain your date and time settings, it shoud not be unpluged for long periods.
Apr 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Feb 15, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5100
buy new power suplly for it ok
Feb 11, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension 5150 (DIM515MIN) PC Desktop Logo
475 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
