Question about Casio FX-9750GPlus Calculator
Solver mode in equations part of calculator
On solver mode I only get one possible answer for the equation I type in, when there are sometimes two. What am I supposed to do to get both possible answers?
  • Casio Master
  • 8,016 Answers
Your Solver is a numerical solver not a symbolic one. You have to supply an initial guess at a solution and the Solver finds it. If you suspect, or know, that there are others jut run the solver again supplying the initial guess for each additional solution.
One easy way to locate the roots of an equation is to draw the function (without =0) and see on the graph the approximate values of x where the function vanishes. These approximate values of the roots can be used as initial guesses in the Solver.
Posted on Jan 01, 2010
How to use casio 9850GC PLUS to solve equations in polar form?
Put the calculator in Equation solving mode. Select F3:Solver. Enter your equation; use X as unknow (no need to use Theta, the name of the variable is irrelevant.) Besides if you use theta you will get a syntax error.
Jun 29, 2012 | Casio CFX 9850GB Plus Calculator
How to find values of x in higher order equations(above cube) on casio 570 ES?
In equation mode, you have system of linear equations (3 unknown) you have polynomial (quadratic and cubic), and solver. Use the solver foe any type of equation (nonlinear, polynomial of order higher than 4, trigonometric, exponential, logs).
May 21, 2012 | Casio Scientific Calculator Fx-570 Fx570...
On the TI83 calculator the equation solver dont workequation solver dont work
Most probable that you are not using the correct syntax.
Press MATH, then scroll down to reach the SOLVER line. Press ENTER. Create the equation, using the ALPHA keyboard to type in letter symbols.
Press ENTER. The screen that opens displays the equation and a list of the variable present in your equation. Each letter (variable) must have a value, except the unknown. If there is a 0 after the = sign on the same line as the unknown, you must clear it so as to leave a blank.
Specify the lower bound and the upper bound to speed up the search.
Once finished press [ALPHA][ENTER] to execute the (SOLVER)
Oct 20, 2011 | Texas Instruments TI-83 Plus Calculator
ON MY SCIENTIFIC CALCULATER ON THE TOP RIGHT CORNER THERE IS AN a BESIDE THAT A 1 AND THEN A ? UNDERNEATH THAT THERE IS AN m WHERE THE NUMBER IS IT SAYS simul???
Calculators come in multiple shapes and makes. It would certainly be helpful to know a calculator's manufacturer and Model number.
The Simul button allows you to use a solver of simultaneous linear equations.
You must have enter one of the simutaneous equation solver.
Enter the value of a_1, press =. For each symbol with a ? enter a number and press =
It will give you the solutions.
You must get out of this mode to do other types of calculations. Read your user's guide to know how.
Sep 12, 2011 | Office Equipment & Supplies
2c + 6 + 7c = 8
To solve this with a ti-84 press [math] and select solve from the menu. This will open the equation solver. Type in your equation
(Note: you may need to put it in the form with 0=, So the equation would be 0 = 2c + 6 +7c - 8 ). Then press
enter or arrow down button.
Mar 30, 2011 | Texas Instruments TI-84 Plus Calculator
I need straightforward key strokes for a casio fx115 es graphing calculator to solve linear equations. I have the Manuel but it only confuses me. this is an example of what I'm solving ...
This calculator doesn't really support a solver like that. You can use Woflram Alpha to solve equations like that really quickly. Example
There are more expensive calculators that will solve these types of equations, but I would recommend just using Wolfram Alpha whenever you need a solution to a math problem.
Mar 02, 2011 | Casio FX-115ES Scientific Calculator
This calculator model ti 85 can to searching equations of cubics?
There is nothing for directly solving cubics, but the general purpose Solver() function can be used for this. For example, given the cubic x^3+x^2=125 with a guess at a root at 4, Solver(x^3+x^2=125,x,4) will produce an answer of about 4.64. Full details are in the manual in the "Equation Solving" chapter.
Feb 22, 2011 | Texas Instruments TI-85 Calculator
Multiple equation solver
There are a few routines to solve simultaneous LINEAR equations that are embedded in the Operating system of the calculator.
  1. solve(
  2. Simult(
However if you are looking for the simultaneous equation solver application, you can download it from the TI website. Here is the link
If you need download and install instructions, you will find them here.
Aug 01, 2010 | Texas Instruments TI-89 Calculator
SC-6103 aurex prestige calculator
You must have pressed the MODE key followed by SOLV , QUAD or SIMUL-2 or SIMUL-3 . If the calculator has these a programs they solve a Quadratic equation, a simultaneous system of two linear equations (SIMUL-2) . a system of 3 linear equations (SIMUL-3).
To use these solvers (IF YOU ARE INTERESTED), you select the solver you want and you will be prompted for a first coefficient (a, or a1). You enter the value and press the DATA key and you will be prompted for the next coefficient.
To exit the Solver mode press the MODE key followed by the key next to which there is DEC or >DEC. It might also be marked COMP.
Sorry, I do not have that very calculator but an other AUREX Scientific calculator (DS-752C).
May 31, 2010 | Casio fx-300ES Calculator
Solver not working properly
try a simple equation like x^2-1 which should come out with x = 1,-1
no sign change would indicate that the graph of the curve never crosses the x axis, if you graphed the above equation and calculated the zeros, it would come out with -1, 1 which it should, but if you put in x^2+1, the graph would never cross and therefore have no sign change from pos to neg or vice versa, the left-rt are the left and right bounds or the lower and upper bounds which was corrected in later calculators, Please let me know the outcome of graphing both of the above equations and then putting them in the solver. you could also use the quadratic equation to prove the answers if you liked, hope this helps
Mar 13, 2008 | Texas Instruments TI-83 Plus Calculator
Casio FX-9750GPlus Calculator Logo
367 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
