Question about HP Office Equipment & Supplies
I am getting a cartridge error. The cartridge is not a new one and it had not been removed. I followed the insructions in the book for cleaning the copper colored contacts but to no avail. I have turned off the printer and left it off for several hours but nothing seems to work. Where do i go from here?
  • 4 more comments
  • melkayok Nov 20, 2008
    The error is"Cartridge Error : remove and re-insert cartridge on right side"
    The model # is 5610v all in one and the black cartridge is # 56 and the color is # 58.
    by the way the color print jet is much smaller than the black one
    That is right and that is how they are inserted. the color is left the black is right.
  • melkayok Nov 21, 2008
    I have at the present time # 22 inserted in ther left side and # 56 inserted in the right side. I have purchased another 56 and a 58 but have not attemped to use them yet. i know the 58 will have to go in the right side when I use it even tho it is a color jet. I'm very sorry if I confused the issue.
  • comment
    comment May 11, 2010
    What is the error?
    Scholar:
  • 78 Answers
The tricolor cartridge always has to go in the LEFT side carrier.
The 56 Black or 58 Photo have to go in the RIGHT side carrier..
Posted on Nov 20, 2008
    Scholar:
  • 78 Answers
OK, If the printer has 2 or more print cartridges, then certain cartridges must be inserted into the correct carrier. Make sure you have not mixed / switched the cartridges into the wrong carrier..
ALSO, What printer model number? And, what is the cartridge number?
  • comment
    comment Nov 21, 2008
    Finally then, Make sure the # 58 is not on the left side. I know the # 58 is a Photo Cartridge, and even though it is COLOR, it can not be used in the LEFT tri-color carrier.. Only the tri-color cartridge probably a # 27 can be used in the LEFT Carrier..
    For some reason you seemed to want to insist that the # 58 was the "color", and therefore should work in the left side, but it will not work in the LEFT carrier, only the Tri-Color..
    I just want to make sure you understand that, because the error is very specific to the wrong cartridge being inserted, in that you can not have the # 58 in the LEFT carrier..
  • comment
    This may help in troubleshooting
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    OR Temporarily...
    Step 5: Print in backup mode
    If you do not have a replacement print cartridge, you can still print in ink backup mode. Simply remove the problem cartridge, and print with the remaining cartridge.
    • If you remove the tri-color cartridge, printouts will be in grayscale.
    • If you remove the black or photo cartridge, the product prints slowly and the colors in the printouts might differ.
Brand new lexmark original cartridge is not recognised. error report' no cartridge'. all contacts cleaned machine dismantled and cleaned and reassembled. has done this before on occasion with refilled...
1. Open the top front cover of the printer. If the display DOES NOT read Close cover or Insert cartridge, the 32 error is not caused by the toner cartridge and printer service will be required to fix the problem.
2. Make sure the correct toner cartridge is installed for this printer model.
1. Check Lexmark for a list of compatible cartridges for your printer.
2. If the wrong toner cartridge is installed, remove it and install the correct one.
3. If the correct toner cartridge is installed, it may not be seated correctly. To ensure that this is not the cause of the error, do the following:
1. Turn off the printer.
2. Reseat the toner cartridge.
3. Close the lid.
4. Power the printer back on and check the display.
4. If reseating the toner cartridge does not clear the error message and the error started as soon as you installed this particular toner cartridge, the cartridge may be broken. You can check this as follows:
1. Power off the printer and then reinstall the old cartridge. (You can also try a different new cartridge to see if that clears the error.)
2. If the error does disappear, the problem may lie with this cartridge. Please contact the point of purchase, especially if the cartridge is brand new out of the box.
5. If the error cannot be cleared by putting in a new toner cartridge or one that is known to be working, the printer may require service to fix the problem.
May 02, 2011 | Lexmark X2350 All-In-One InkJet Printer
5100 error message
Hello and Welcome to FixYa!
Error 5100 means that the cartridge can not be detected by the printer
Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps
  1. Turn off printer
  2. Remove both the cartridges from the printer
  3. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  4. Return the cartridges
  5. Turn on the printer.
Error will be removed.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Canon PIXMA MP540 All-In-One InkJet...
Error message "remove and check cartridge on right" Did that and shook up the cartridge still feels like it has ink but when I replace it the message does not go away. If it is truly out of ink why doesn't...
Step 1 - Remove and reseat the cartridge
NOTE: The "problem" cartridge is the cartridge indicated by the error message.
  1. Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge. Figure 1: Removing the cartridgec00143341.gif
  3. Pull the problem cartridge out of the print carriage.
  4. Inspect the cartridge. If the cartridge is new, make sure to remove the protective tape covering the nozzles.
  5. Reinsert the cartridge into the carriage at a slight angle, as shown in the illustration below. When the cartridge is fully inserted into the carriage, rock it upright. Figure 2: Reseating the cartridgec00143342.gif
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration below. Figure 3: Closing the cartridge latchc00143343.gif
  8. Close the cartridge access door.
  9. The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Step 2 - Clean the contacts
NOTE: Try to clean the contacts quickly enough that the cartridges are not outside of the unit for more than 30 minutes. The ink can dry and clog the nozzles if the cartridges are outside of the unit for too long.
  1. Gather the following items to clean the cartridges and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
  2. Remove the problem cartridge.
  3. Place the cartridge on a piece of paper with the nozzle plate facing up.
  4. Unplug the unit power cord.
  5. Lightly moisten the lint-free cleaning material with clean water.
  6. Clean the cartridge contacts. Avoid touching the nozzles. Replace the cleaning material if it gets dirty. Figure 4: Cleaning contacts (avoid nozzles)c00143349.gif
  7. Clean the carriage contacts. Use new cleaning material if the material used on the cartridge contacts is no longer clean.
  8. Let the parts dry for five minutes before reinserting the cartridges. Figure 5: Cleaning carriage contacts c00143350.gif
Step 3 - Remove cartridges and shut down the printer If the steps above have not helped and the error message is "Remove and check the right cartridge ," the following steps may help:
  1. Remove both cartridges, lower the latches, and close the printer access door.
  2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
  3. Turn the printer back on by pressing the On button.
  4. When the message display reads Insert right cartridge , open the access door and replace the cartridges.
Step 4 - Download a firmware updateIf the error is still displayed, follow the steps below to see if downloading a firmware update from HP might help:
  1. With the power on, open the printer and remove the cartridges.
  2. Relatch the empty carriages and close the printer.
  3. Open the printer and reinsert and relatch the cartridges.
  4. Close the printer and look at the LCD display.
    • If the LCD now shows no error, the original error was caused by a problem that is fixed by HP's firmware update. Though the error has cleared, it may come back in the future, or other problems such as slow printing may occur. To fix these problems, download the latest firmware update from HP. Click here to see how. Make sure to download the firmware update, rather than a driver or other software.
    • If the error message is still displayed on the LCD, the firmware update probably will not fix the problem. The update does fix other problems however, and it should be installed when it is convenient.
Step 5 - Replace the cartridge or service the printerIf the steps above have not helped, replace the cartridges or service the printer. Replacing the cartridges can help determine whether a problem is caused by the cartridges or the unit. However, cartridge replacement will not solve problems that are caused by the unit.
  • If you have not previously tried replacing the cartridges to solve the problem, or if replacing the cartridges solved a similar problem in the past, replace the cartridges now.
  • If you have already tried cartridge replacement without fixing the problem, the unit may need to be serviced. Contact HP to see how to proceed. Click the link at the top of this page for contact information.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Will not print, shows error
One cartrige is broken replace it with a new one..
Sep 24, 2009 | HP PSC 1350 All-In-One Thermal Printer
Hp 1410 all in one keeps saying prin cartridge error
Follow the steps given below and check for the results
=== Cleaning the ink Cartridges ===
Even if the cartridge is new, follow the steps below to clean the print cartridge contacts. Print cartridges have a substance on the contacts to keep them from corroding during storage that may cause poor electrical contact between the print carriage and the print cartridge.
  1. Verify that the product is turned on. NOTE: If the HP product is not turned on, you will not be able to remove the print cartridges.
  2. Open the unit to access the print cartridges.
  3. After the print carriage (the part that holds the print cartridges) stops moving, unplug the power cord without turning off the unit using the power button. If you turn the unit off the print cartridges will be capped to prevent them from drying out and you will not be able to remove them. You must unplug the power cord to prevent the print carriage from moving.
  4. Remove both print cartridges.
  5. Verify that the part number on the cartridge is the correct part number for the unit.
  6. Using a cotton swab or lint free cloth (like a coffee filter) lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the cartridge. Figure 1: Electrical contacts c00055424.jpg NOTE: When an all-in-one is used frequently for black and white printing but infrequently for color printing (for example, an all-in-one that is used primarily as a fax machine), the color cartridge will still eventually fail and need to be replaced. The pins in the print carriage can cause dents on the contact points of the color cartridge over time (usually between six and twelve months).
  7. Wipe the contacts with a dry, cotton cloth, as shown, to dry the contacts and finish cleaning. Figure 2: Wiping the contacts c00055425.jpg
  8. Reinsert the cartridges and lock them in place.
  9. Close the top cover or access door and plug in the power cord.
  10. If the error continues, repeat these steps. If further cleaning fails to clear the error, proceed to "Step two: Cleaning the print carriage contacts" below.
Step two: Cleaning the print carriage contacts Have the following materials available to clean the print carriage contacts:
  • Cotton swabs or any soft material that will not come apart or leave fibers.
  • Distilled, filtered, or bottled water (tap water may contain contaminants that can damage the print cartridges) CAUTION: Be careful not to get ink on hands or clothing.
Do the follow to clean the cartridge contacts inside the product:
  1. If the unit is off, turn it on.
  3. After the print carriage stops moving, unplug the power cord. Do not turn the unit off before unplugging the power cord.
  5. Using a cotton swab or cloth lightly moistened with distilled, filtered, or bottled water, clean the electrical contacts of the print carriage as shown below. Figure 3: Cleaning the carriage contacts (your model may look slightly different) c00130268.jpg
  6. On models equipped with locking latches, lower the latches. Figure 4: Latches in the lowered position (your model may look slightly different) c00055427.jpg
  7. Wait five minutes for the contacts to dry and then plug in the power cord. The unit will begin to reinitialize. Wait until the process is complete before proceeding.
  8. Reinsert the print cartridges when prompted and then close the top cover or access door.
  9. If the message recurs, replace the print cartridge indicated by the message. If you are using refilled or remanufactured cartridges or non-HP cartridges, replace them with new HP cartridges. HP cannot guarantee that refilled or non-HP cartridges will function correctly in HP products. If a new HP ink cartridge is defective, return it to the place of purchase with the receipt, or contact HP to obtain a replacement.
  10. If the problem still exists, replace both print cartridges. Since the cartridges are electronically connected through the printed circuit board, the cartridge not indicated in the message might be the causing the failure
If the issue still persists then try the following steps to identify the problem ink cartridge
1. Remove both the ink cartridges
2. Insert the Color ink cartridge first and close the ink access door
3. Check if you are getting any error message or the ink cartridge light is blinking
4. Now remove the color ink cartridge and then insert the black ink cartridge and close the ink access door
5. Check if you are getting any error message or the ink cartridge light is blinking
Replace the problem ink cartridge anc then check
May 17, 2009 | HP PSC 1410 All-In-One InkJet Printer
Printer message is 'remove and check cartridge'. have done that and put in new cartridges but message stays. can print a test page but it will not print anything else
I assume something has happened during a print job and you are seeing this message on the 6110's control panel display. Either there's a "clog" in the flow of ink or an issue with the electrical contacts between the cartridge and the print carriage. Unfortunately, HP.com doesn't list this error message on the web page for 6110 errors.
You can go to the following web page and follow the instructions to clean the electrical contacts I mentioned. The problem you are seeing can also be caused by an incorrectly installed ink cartridge or one where the protective tape strip was not removed before installation.
The latter is likely if you see this error message right after you've put in a new ink cartridge. It's easy to put the cartridge in incorrectly or not to correctly latch it in place. It's also really common to forget to take the tape off before installing the cartridge.
Here's the relevant link:
Cleaning the Print Cartridge
Good luck and post back your results.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    94 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
