Question about HP Photosmart 715 Digital Camera
Digital camera The battery compartment door has one of the pins broken off, it makes it impossible to close the door.
I have the same problem with mine...i just close it with duct tape...funky but it works
Posted on Jun 03, 2008
I can put fresh batteries in the camera but it will not turn on what can I do to fix it
Could be that the contacts in the battery compartment are bent or broken. Visually examine. Also most cameras have a switch activated by the battery access door - when the battery access door is closed that switch gets activated and allows the camera to turn on. That switch might not engage properly if the battery door is damaged or doesn't close properly.
Feb 10, 2016 | Cameras
Battery door not locking nikon s560
hiwould you show the broken area? you can post picture the broken area if you have extra camera. there is one thing you should check battery door hook, post, and battery compartment area. please make sure what really broken then I can help
Jun 03, 2011 | Nikon Coolpix L11 Digital Camera
Fujifilm S1500. Batter compart doesn't close
If you can't return the camera for service, my advice would be to close the battery compartment with tape. Not pretty but better than buying a new camera, I've done it a few times on old cameras and apart from cosmetics, works fine. Just make sure to use enough tape so the batteries won't fly out when using it.
Jul 14, 2010 | Pix FUJIFILM Fine S1500fd Digital Camera
I dropped my nikon coolpix l14 camera and the part that keeps the battery compartment closed chipped, so now the battery compartment will not shut by itself and needs to be held by a rubber band.
I did the same thing and decided to try and fix it myself. Here are the steps to follow after you acquire the new door, which is available online through Boca Photo for about $16 plus shipping.
On the bottom of the camera remove the three small screws and the one bottom screw on the side (left corner) of the camera. With these four screws removed you then gently pry the camera apart at the seam so it opens about 1/8". Then pull the battery door up and you'll see the steel pin the door pivots on. Pull the door and pin up and out and then slide the steel pin into the new door and reverse all the steps.
Jun 24, 2010 | Nikon Coolpix L14 Digital Camera
FE-140 Battery compartment door broken
you could try and put all the info about your camera in to google search..or the same on ebay.
Oct 27, 2017 | Olympus FE-140 Digital Camera
Broken battery compartment door switch
The switch is a micro switch that is depressed(and not sad :)) by a plastic tag moulded on the battery cover. Once the cover is moved into position and closed, the tag presses on the micro switch closing the switch and thus removing the error message. As with any switch, a switch is simply open or closed, Open = high resistance or O/L, while closed = 0 ohms reistance. You can use a small wire to overcome the switch by soldering the wire to both tags of the switch so it is permenantly 0 ohms. This will send a message to the microprocessor that cover is closed and camera ready for use. Hope this helps.
Twitcha
Sep 28, 2008 | Olympus FE-140 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
HP Photosmart 715 Digital Camera Logo
173 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
