Question about Mk Diamond MK - 770EXP
Water flows for cooling but saw does not rotate
MK 770 Tile Saw
  • 359 Answers
Check to see if the motor has overload reset button on it (red) usually the water is only pump portion of circuit and can run independent of motor circuit , if not check wiring to motor circuit
Posted on Dec 03, 2008
I am trying to find an wiring diagram for a tile saw mk-660
Here is the website you need to find the manual and wiring diagram for your saw
Hope you find what you are looking for
Nov 30, 2009 | Mk Diamond MK - 660 Electric Tile Saws
MK water saw - water goes every where but on the blade!
When you say you turn the pressure up, I presume you mean you are opening the suction on the side of the pump.
On the saw which I have used in the past it is difficult to aim the warter spray. I opted for more water (open the suction on the pump) and let it go. most of it went onto the saw blade - some went onto the tile, some on me and some on the wall --- put a piece of cardboard or something behind your saw to help contain the overspray.
Sep 07, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Water pump will not pump. I've checked for clogs and it is clean. any suggestions?
Check for a volume dial on the side of the pump--it may not be obvious at first glance, but if there is one check to ensure it is set to something other than the minimum flow.
Also, when you put the pump in the water, make sure it is completely submersed, and fill the supply side hose with water to prime the pump.
Aug 10, 2009 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Tile saw tripping breaker even after letting it cool down for 24hrs .
2 things first what is the motor rated at for AMPS and second the circuit you plug it into what is the rating. The saw will draw more than the namplate rating for startup but it would still pull a lot and if you have something else on that circuit it could be causing the problem assuming there is no major electrical problem with motor
Jul 02, 2009 | Mk Diamond MK 101Pro Tile Saw
The saw in not pumping water
I have came across to possible solutions with other tile saws in the past. One is that your pump could have picked up a small piece of tile or sedement from the basin and got stuck in the water port where it comes out on to the blade. The first thing I would try is to disconnect the hose frome the blade shroud while saw is off. **** on the end of the hose until you get water. Sometimes the line needs to be primed and filled with water. Once you get water you can turn the pump or saw on while disconnected to see if water flows. Keep loose hoses away from blade though! If nothing then try the blocked port. Good luck
Dec 03, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Blade replacement on mk-170 tile saw.
take a pair of good vise grips and hook onto blade tightly, slide uo against back braket. that will hold the blade from spinning while you remove the nut, try bumping your ratchet/ wrench w/ a rubber mallet or hammer. hope this helps
Oct 29, 2008 | Mk Diamond MK - 170 Wet Cutting Tile Saw
Tile saw helping tools
On most of the tile project you will need: tile nippers, 1/4", 1/8" and 3/16" spacers, grout sponge, mixing tub, mixer and various trowels.
Aug 27, 2008 | Mk Diamond MK 101Pro Tile Saw
Mk Diamond MK - 770EXP Logo
262 people viewed this question
Top Mk Diamond Saws Experts
JonSnell Electronic
JonSnell Electronic
Regalo Tiles
Are you a Mk Diamond Saw Expert? Answer questions, earn points and help others
