Question about Sony KP-53HS10 TV
Sony projector kp53hs10
My Sony kp53hs10 projector TV will turn on and show the picture for about 30 seconds, then it goes blank. The sound continues to work.
  • 1 more comment
  • legold5 Dec 06, 2008
    seet was working fine when suddenly bean having convergence  problem the flash focus would not fix. sound was fine. then picture began to blink off and back on at random times...
  • niwri Jan 05, 2009
    Whether I'm watching Direct TV, Tivo, or DVD my TV will play for 5 to 10 minutes then the picture will disappear and the screen will remain blue without a picture but the sound will remain perfect. Sometimes the picture will reappear in about 5 to 10 minutes and then disappear again. I have eliminated the Direct TV, the Tivo and the DVD player. It is definately the TV. TV is 8 years old with very little use. Maybe 5 to 10 hours per week. I've tried loose out to power, to devices etc.
  • jaynie111 Jan 05, 2009
    my problem is similiar. the screen will go black for just a second, while still having sound. sometimes it only happens when a commercail is on? i took off the front speaker panel, but couldn't find the knob for adjustments. do i have to tear it down more? thanks
  • 4 Answers
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Posted on Dec 03, 2008
I have a Sony KP53HS10 projection tv, occasionally the picture will move in and out around the edges kind of shrinking and growing as if the focus is adjusting. the screen goes blank and the red led in the...
You have a weak capacitors in the power supply. Your description has enabled me to say this is the solution. We TV techs call this "breathing". You may control some of this with raising the contrast and brightness to see the picture stabilize.You will need a TV tech to correct the power supply. I have not worked on projection TVs for some time. This is a classic problem with a classic fix. Thanks for asking and show all hands of support!
Sep 13, 2011 | Sony KP-53HS10 TV
When I turn the TV on, it has good picture, then 30 seconds the screen goes blank, then 30 seconds later it comes back on. Repeating this continuously. What do I need to do.
Its time to replace Lamp in tv as current lamp is near to an end of its life and causing this problem.
Lamp replacement is easy and user level job, procedure would be mentioned in user manual.
Please buy Sony original lamp for better picture quality.
Let me know if you have additional question.
Thanks.
Apr 12, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My sony wea lcd 60 inch television goes blank with no sound every 5 minutes or so for about 30 to 45 seconds then the picture and sound come back the set is just over 3 years old
Symptom shows TV needs new lamp and existing lamp is getting weak / dying.
Replace lamp in TV and procedure is written in user manual.
Let me know model number of TV if you need user manual copy.
Thanks.
Oct 02, 2009 | Sony Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Picture and sound first turn on before disappearing over and over again.
Symptom shows its weak Lamp problem in TV and you need to replace lamp. Replacement procedure is easy and written in instruction manual of TV.
Always buy Sony Original Lamp from Sony Accessories for longer life of TV.
Apr 25, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kp53hs10
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Dec 22, 2008 | Sony KP-53HS10 TV
Just sound
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
Feb 26, 2008 | Televison & Video
Sony KP-53HS10 TV Logo
285 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
