on my magic sing microphone, everything works, melody,tune etc. except no voice is coming out when use to start singing. no vocal at all coming out. please advise.
I have the same problem. I've tried everything. Emailed for assistance and he said we needed to get a new rca cable, but the rca cables are part of the microphone!
Everything else works perfectly. We've only used ours about 1/2 a dozen times, so the problem isn't due to wear and tear.
Help would be much appreciated!
Same Problem
Dec 29, 2008
-   everything is working video & music except from the mic itself no sound coming from the mic.
-   Danicka29
Nov 20, 2008
-   Inhave an entertech ed9000 - worked for a couple of months - maybe used 10 times max- same problem - can't find anyone to repair - any suggestions?-   chrisq2gua
Nov 06, 2008
-   Same thing. Everything works, except the mic part. Voice doesn't come out. It's not the RCA because you can hear the music. It wasn't working for a while, but one day my son was playing with it and it started working for that day only. After that went back to no voice.
I'm thinking he might have pressed some kind of reset sequence which made it work.-   Guest
Aug 04, 2008
-   No sound comes out of microphone. Sound and music works on tv but no sound from mic. This may be a little older model its called magic mic ll.-   Guest
Jul 25, 2008
-   Same Problem. My friends who knows electronic can take a look but doesn't know how to open the mic body. Anybody?-   dgreat69
hi there..if there is video and background audio coming out from the TV, and no voice recognition from the mic- then mic is the problem. I believed the problem is the "voice coil". This is a part that can be replaced- you can contact me and we can repair that.
two ways to check remove the mic ball the part which the mic ball is is covering is the voice coil. try holding both terminals (black and white wire)- if there is feedback sound- it is open and need to be replaced try using your tester- test the impedance- there should be 500- 600 ohms reading
(sean.delcarmen@magicmic.com or customerservice @magicmic.com)
Microphone is only 1 month old, maybe used 3 times. It was weorking fine and then today everything...
(More)
Microphone is only 1 month old, maybe used 3 times. It was weorking fine and then today everything seems to work but no sound comes from the microphone?
I have an entertech ed11000 magic sing Karaoke machine and I can;t seeem to get audio and video....
(More)
I have an entertech ed11000 magic sing Karaoke machine and I can;t seeem to get audio and video. When you turn on the power the blue light goes on but that is it. No picture and no sound. Just got a new adaptor for it. Can anyone help? Thanks!
our magic sing microphones keep blinking..saw the trouble shooting page it says press 0 and then...
(More)
our magic sing microphones keep blinking..saw the trouble shooting page it says press 0 and then power but still nothing happened..did we do something wrong with the steps? can anybody help us connect our microphone?
good evening i have my wow magic sing 6 month palang ito pro last night ginamit namin ito but...
(More)
good evening i have my wow magic sing 6 month palang ito pro last night ginamit namin ito but suddenly nawala ang sound but the vidio and lyric still okay ano po bang problema thank you very much
everything works on the microphone but when you sing, you can't hear your voice and the karaoke program rates your score as 0 which makes me think it is not picking up the voice at all. any solutions?
