Question about HP LaserJet 4250n Printer
Printer won't print
Printer window says: 60.02 error
    Scholar:
  • 136 Answers
60.02 is the tray lift motor error,
Chances are the tray is not being lifted to the paper feed tires
the moter is on the side of the printer, if you know how to replace great
if not you can call a Printer tech in your area. were listed in Ct.
Posted on May 01, 2009
  • HP Expert
  • 141 Answers
60.2
printer error
The tray 2 lifter-motor is not functioning. 1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
This is straight out of the manual.
Tray 2 lifter-drive assembly
Remove the following assemblies:
● Rear accessory cover. See Accessory covers and the tray 2 extension door.
● Top cover. See Top cover.
● Right-side cover. See Right-side cover.
● Formatter cover. See Formatter cover
● Formatter. See Formatter assembly
● Paper-pickup drive assembly. See Paper-pickup drive assembly.
2 Unplug the tray 2 lifter-drive assembly connector from the dc controller PCA (location J93) and
the two flat cables (callout 1, locations J80, J81). Unweave the wire-harness from the cable
guide (callout 2).
NOTE You might have to remove additional wire-harnesses from the cable guide to gain
access to the lifter-drive assembly wire-harness.
Figure 6-51 Tray 2 lifter-drive assembly (1 of 3)
Main assemblies 227
Unhook the tension spring (callout 3) at the lifter-drive assembly, remove one screw (callout 4),
and then slide the support plate (callout 5) out of the printer.
Figure 6-52 Tray 2 lifter-drive assembly (2 of 3)
228 6
Rotate the top of the lifter-drive assembly away from the printer to remove it from the printer.
NOTE You might have to remove some cable guides to easily remove the lifter-driver
assembly.
Figure 6-53 Tray 2 lifter-drive assembly (3 of 3)
Main assemblies
unfortunately i couldn't paste the pictures to help you.
Assembly is the exact reverse of removal, Good Luck!
Posted on Nov 20, 2008
Windows Live Mail won't print on Windows 7 64bit
Try to check if your printer is set to Default.
Go to Control Panel > Devices and Printers> Under Printers and Faxes, locate your Printer name then Right click> Set as default printer.
Then try to print again.
Hope this helps.
Regards,
Charvin
Oct 15, 2012 | Brother MFC-5840CN All-In-One InkJet...
Printer won't work with HP WIndows 7
I regret to inform you that the Lexmark X75 does not support Windows 7. It works on Windows XP and previous versions.
You may contact Lexmark Technical Support Center to check for other options.
Feb 20, 2012 | Lexmark X75 All-In-One InkJet Printer
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
As soon as I press print on my computer the error light on the printer goes on and it won't print
Hello:
First try uninstalling the printer drivers in windows, and check for driver updates on your manufactures website. Reinstall the drivers and software and try printing again, If problem persists then you may have a hareware issue in the printer or comm problem.
Sep 09, 2011 | Brother HL 2140 Laser Printer
Zebra 2844 Printer was fine...unplugged USB then plugged into a different port on the same computer now it won't print. Says error in the printing status. It is not offline or paused.
This is due to windows which has attributed a new virtual usbport.
Go to the printer port and try another one (the last one for example)
Jul 31, 2011 | Zebra LP 2844 Thermal Printer
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Marca error 60,02
60.2
assembly.
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
HP LaserJet 4250n Printer Logo
487 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
