SOURCE: my HTC sensation randomly turns itself off ....
Check if there is any lose in the battery. I will shot that this is software malfunction. Probably software upgrade will fix it.. But start from putting small piece of paper between rear cover and battery. Or shake a little bit phone to check if its going to turn off
SOURCE: the gps on my htc sensation 4g doesn't work
First, make sure that your GPS issue is not a settings issue. Try going to settings > Location & Security > Make sure "Use GPS satellites" is checked.
If that does not fix your issue, restart the phone, retry the above process and try it again.
If all else fails, your GPS module and/or software is broken or corrupted. Contact your service provider for a warranty replacement.
SOURCE: my htc sensation won't turn on it has a white screen
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
78ABCDEFG |
G cont.H
IKL |
L cont.MNOSTVXZ |
When on Disk drive mode, you will not be able to use apps on HTC Sensation XL with Beats Audio that access the storage such asCamera.
HTC SyncSelect this option to synchronize contacts, calendar, and other information between your computer and HTC Sensation XL with Beats Audio.USB tetheringWhen you do not have an Internet connection on your computer, you can select this mode to share the mobile data connection of HTC Sensation XL with Beats Audio with your computer.Internet pass-throughIf you don't have a data plan or you don't have access to a Wi-Fi network, you can select this mode to share your computer's Internet connection with HTC Sensation XL with Beats Audio.
