Ok, I have a dvd drive that wont read discs of any kind. Blank discs, music, dvd's and even software. According to HP, it has SATA and not ATA but when I go to Device Manager, it says my Dvd Drive is ATA. It trys to read the discs but nothing even happens other then my computer gets hot. Does anyone have any idea what is going on or what I should do? (Please, no silly or goofy remarks or answers)
Insert the DVD burner software that comes with your SATA burner. This will have the driver or go to Windows Updates and see if the driver software is there for you to download. The problem could be a region set or it is not populated.
I have had to set my region setting to 1 which is the US then populate it. And make sure the right driver was installed for my device if you do not have the driver disc or files go to hp.com and download it from the support and drivers section of the manufacturers web site it will be there. Make sure that you have the right info typed in when hunting drivers.
If it is a third party addition you can also get the driver files from Lightscribe they will also have the drivers that is about all you do. John
Sorry it took me so long to reply been really busy with questions. Populate the drive means just see if it will read and pick up the information for the device. If you have a code 32 it means the driver is not installed for it. Seems to me that since Win 7 went on the machine if you go to Windows updates which is standard with new software installs to get offered drivers I bet the driver or files will be in the update section you can go to Windows updates and see by clicking on the start menu go to Windows updates then select Check for Updates. See if anything shows for a DVD or CD rom driver. It may be an old player so Win 7 may not support it. That is when you go to the manufacturers web page and click on Win 7 updated software for your devices. If that does not solve this go to Microsoft's Fix It for You it analyzes your computer and installs or refers you to the place to get the driver files.
I had a sticky situation myself and used the Fix it for me software from Microsoft and I got a driver that was hard to find on my own given to me and repaired now. Yes Win 7 may have something to do with the old driver for the DVD player not to work it is not serious you should be able to find updated versions for your devices.
I hope that clarifies some things for you. John
Copy and paste this link in a browser of your choosing and follow the instructions to the letter and see if it solves your issues. John
http://www.lightscribe.com/downloadsecti...
SOURCE: download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
It is not an uncommon problem. The solution is here:)
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
SOURCE: hp Pavilion dv6000's dvd-rw won't work
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
SOURCE: Drive needed for my dvd drive(Slimtype DVD A DS8A1H ATA Device)
Here is a link to all your drivers you can try reinstalling it from here, click here for page. hope this helps
my drive is LightScribe SuperMulti 8X DVD+/-R/RW with Double Layer Support.
It is also a SATA dvd drive. It acts like it is reading or trying to read but nothing ever pops up and if I double click on the drive to open it, it tells me to insert a disc when there is a disc in it.
There is no cd that came with it. It came from HP not the store. Populate? How do you do that? I didn't have this issue until my Husband put Windows 7 on it. Could that be the issue?
I ended up buying and putting in a new dvd drive. That fixed it!
