Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
KP51WS520 will not turn on. Light blinks 9 times.
Can you explain to me what might be the problem and how to begin to fix this problem. Is there a service manual that will show diagrams of the various boards, which ones to diagnose and which parts to replace? Also, where can I purchase replacement parts? Thanks in advance for all your help.
  • jeb082004 Nov 22, 2008
    i have the same problem. should i just call someone to fix it??? How much am i looking at??? can i fix it my self????
  • Stan Tabor Nov 27, 2008
    I am having the exact same problem. The TV will not come on. Only the standby light blinks.
    New Friend:
  • 99 Answers
Hi there...
let me see if I can help u out, but before u try anything, be careful not turn or remove un necessary wires, if u do, document them and also this set operates at high voltages. If u are confident enough, then go ahead and check the following.
First of all the 9 blink is ZCD fault located probabply on G Board. I believe it will be at the left most side of the set. when U are looking from behind the set once the back cover is removed u can see 3 boards on the main bracket assy. from ur left is G board then D board and the A board.
To make it easier for u just look at the power code connected board, that will be the G Board
On this board u'll find 4 pin connector labelled CN6012. The pin no. 4 is the ZERO_DET. pin.
Check the associated circuit connected to this pin. Mainly there will be two diodes that will create such a fault. They D6116 and D6301.
Post back after checking this area
Posted on Nov 20, 2008
Sony model no KP51WS520 red light flashes 9 times but wont turn on
Check if the TV is in an AV mode.
Normally if I leave my TV in an AV mode with nothing plugged in, it starts flashing the red led..
If no luck return it
Mar 17, 2012 | Sony Televison & Video
Trouble code: Standby LED blinks 9 times
You will need to replace the G board on this tv to fix the problem
Aug 13, 2008 | Sony KP-51WS510 51" Rear Projection...
I have a sony 52" rear projection tv red light
I will need the model number to assist if its the KP51WS520 the 9 blinks is zero cross diodes on the g board.
Aug 02, 2011 | Sony Televison & Video
Sony KP51WS520- stand by light flashes 9 times and won't turn on. Have unpluged for 4 hours, still won't turn on.
Unplug the tv, take the back off,locate the G board, next look for D 6301,and D 6116,these are diodes,desolder them and replace them,if that didnot fix it,then change the switching regulator also,its also on G board..use a desoldering iron to remove parts, then wick wire to get the access solder off the pin holes to resolder parts.hope this helps.....
Feb 23, 2010 | Sony Televison & Video
Sony Wega Model #KP51WS520
Press in order on the SONY remote "display - 5 - vol. down - power" .that will show diagnostics indicating 9 Zero Cross Detect . You shoud take it to a servicer.
Oct 18, 2009 | Sony KP-51WS520 51" Rear Projection...
Sony Wega KP51WS520 Stand by Light blinks 10 times
its projection tube problem you need to get new one...
Jul 05, 2009 | Televison & Video
Sony KP51ws520
9 times blink shows Audio Error in your TV.
Let me know if you want to fix it by yourself.
Feb 21, 2009 | Sony KP-51WS500 51" Rear Projection...
TV won't turn on
There's a small diode on the power supply board that causes this. Its identifiable by its purple stripe. You will need the correct type of diode to fix this properly. The diode supplies the standby voltage to the system control circuit, so when it fails, the TV will never come on.
Feb 12, 2009 | Sony KP-51WS520 51" Rear Projection...
Tv won,t come on now
i have a kp51ws520 that i just fixed. it blinked 9 times. found out it was the g board. got it done pretty cheap . let me know if you need more info.
Feb 05, 2009 | RCA Scenium D40W20 40" Rear Projection...
Try pushing the buttons on the remote and let me know what comes up on the screen if anything.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
Jan 13, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
367 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
